SOLD 1994 FZJ80 - 175,000 MILES - Colorado
Status
Not open for further replies.
Beuna Vista
Year
1994
  1. 80 Series
Mileage
175000
Color
Green
1994 FZJ-80 - Triple Locked (ARB) - $18,000 (Nathrop)
1994 toyota land cruiser
VIN: JT3DJ81W4R0082350
condition: excellent
cylinders: 6 cylinders
delivery available
drive: 4wd
fuel: gas
odometer: 175000
paint color: green
title status: clean
transmission: automatic
type: SUV
175,000 original miles (those of you who know, know this is very rare).
Asking $18,000 OBO
Carfax Available. No accidents. Just a little panel damage from the trails. Easily repaired.
Here are the specs and everything currently installed, as well as parts included in the sale:
There is a rust on the rocker panels, clear coat peeling mostly on drivers side. Some body repair at rear drivers side and rear hatch. Cosmetic damage only.
Icon Stage 3 Suspension System (Adjustable remote reservoir shocks with Front Hydraulic Bump Stop)
New factory rear bump stops on Wits End Blocks @NLXTACY
King Suspension steering stabilizer
Front sway bar disconnect
@Delta VS
Delta Vehicle Systems 4” radius arms
Delta Vehicle Systems 3” Panhard relocater
Delta Vehicle Systems front Hydraulic Bumpstop Mounts w/ 1" Spacer
2 New Double Cardan Driveshafts
New Asin Fan Clutch
New Asin Water Pump
New CSF metal radiator
New belts
Nitro 5.29 gears
RCV Performance Front Axles
Nitro Silver Chromoly Full-Floating Rear Axles
ARB lockers front and rear
ARB air compressor, interior switch for front and rear lockers
Center diff lock (4hi & 4low)
Front and rear axle breathers routed to engine compartment
ARB bull bumper
Wet Okele Seat Covers
New brake calipers front and rear
New master cylinder
New exhaust from downpipe to tail pipe, including new catalytic converter
New O2 sensors
NOCO Genius onboard charging with external plug
Optima Red Top Battery
315x12x16 BFGoodrich KO2 Tires
Slee transfer case skid plate
4x4 Labs 3rd row seat baskets
Speski Off-Road Cargo barrier
Kut Snake Fender Flares (front right fender is cracked)
No AC compressor
no speakers installed (have new pioneer speakers on hand and will include)
No Radio installed
Spares:
Full size spare rire on rim
Hi-lift jack
Fire extinguisher
Max Trax (2 sizes)
Willing to include Wilco Offroad Swing out, spare tire carrier.
This vehicle is not exactly pretty but damn is it capable. Interior is in great shape. Will include the original radio and allow buyer to decide on upgrading if need be. With some minor bondo and paint/clear coat, you will have a great looking and most importantly a capable rig. The new gearing helps big time with the CO grades and highway speeds. The vehicle is also calibrated for the large tires and the Speedometer is 100 percent accurate. The rig does not burn any oil at all. Again, super low miles for the year. Engine is in great shape. Regularly maintained with oil, filters, etc.
@Benbmore3d was this purchased recently from another mud member? Trying to remember the member that did the original build, thanks!
Status
