- Thread starter
- #61
Alright - so decent news!!!!!!
One of my friends said it could be a helicoil. So I started thinking.
I was able to thread in a new spark plug. But, it'd crush itself when you tighten it (without the engine running).
After about two hours of scratching my head, thinking I'd have to take the head off...I thought...what if there is a helicoil and it just won't allow you to tighten it down all the way...Maybe it's not centered over the cylinder or something. I'm not too sure.
I put in another new plug, and I made sure the ignition coil was making full contact - keep in mind it is still sticking up about an inch above the valve cover, but the plug is in and undamaged, the coil is on and its making contact, so there should be spark.
whatever is in there, has to be some sort of new thread for the spark plug. And it doesnt allow the plug to be seated as deep into the head as the rest of the cylinders. But it was worth a try.
AND
It worked - it's now running on 6 cylinders. I heard something, resembled a very very slight knock. Let idle for about 30 seconds. Rev'd it up to about 3200 rpm's, the sound suddenly stopped and the truck continued to idle perfectly; minus the small vacuum leaks I still have (which will be remedied here soon). I figure whatever it was, was floating around from the broken spark plug and it got spat out the exhaust.
I'm so relieved right now - and this truck feels SO much better on 6 cylinders haha.
Now to fix the alternator and I think I'm good to begin daily driving!!!!! Going to keep working on it this weekend to see what I can get done.
AND
