Parting Out 1991 HDJ81.... NO ENGINE OR TRANS, Burnaby BC, Canada
Top and lower D bracing for oem rear tire carrier? Thanks
Cruise control cable still there?
If you ever get a truck with a set of the side mouldings that just say "four wheel drive" (not "VX Limited" like this one) I'm interested in a full set.
Cheers.
I've got lots of those. I had no idea that some many people want the side trims. It's crazy.
Following upon Cruise Control Cable.
looking for side mouldings also. I nearly have a full set (misiing two) or id buy a full set from you. In Langley BC, caan come out to you?
you can bolt up any manufactures headlight washer pump. you will need to splice the wires ofcourse. get one that has the same shape. the input shaft is pretty universal
Hello,
I'm looking for same pieces as exakt0h (Top and lower D bracing for oem rear tire carrier)
do you still have some available ? it's almost impossible to find some in Europe
Pierre
