Build 1991 FJ80 - The Long Game | Build Thread | 1UZ Swap
I heard the stock 3FE FJ80 high pressure power steering line will work?
I've got the 91's FJ80 high pressure power steering line and it doesn't have a banjo on the PS pump side unfortunately
Like, unused? I've got one attached to the uz line still. Was hoping the line shop could just hack it off and re-use it no?
Very slow movement on the build....get your builds done before kids boys. Here is some pics of the radiator install and tranny oil cooler install. I will need to redo some AN fittings as after watching some YouTube, I think I incorrectly did some.
Mounts moved right over to my radiator just fine from the old one. I had to do some minor trimming of the mounting flange on the new radiator to clear the core support (seen in sharpie).
I'll have to remount the tranny cooler once I get an AC condenser and finish the AC. will do a better job mounting it down the road.
I'm waiting to see if I can source some upper radiator support bolts from someone on here but other then this, once I finish the radiator mounting and tranny cooler install, I'll start working on the headlight harness and re-looming that as well as the electric fans, hoses and such.
Anyone got a good source for custom silicone radiator hoses?
