1991 Blower Motor question
Lemoore CA
Been looking around and can't find the answer. There are two type of blower motors it appears, one with A/C (discontinued) and one without. I prefer to stay with OEM. Rockauto has the Four Season motor w/ AC for sale without the fan only (go figure) but OEM has the fan only w/ AC for sale but no motor.
Anyone install the below No A/C Blower on a A/C FJ80? Any idea what the difference could be?
Looking at parts.toyota it doesn't list two types of blower motors, it only list this one below, which is the one carried in stock above. No one has ran into this issue of with or without A/C BS? I though AC was standard on FJ80's.
Go to www.partsouq.com plug in your VIN and it will give you any updated part numbers that you can then try to track down. It may show they are the same as current units or not.
8710360150 MOTOR SUB-ASSY, HEATER BLOWER, W/FAN / FJ80, FZJ80 W(AIR CONDITIONER) 01.1990 - 01.1998
Substitution: Part Number: 8710360140
Supersession(s): 87103-60140; 8710360150; 8710460240
No longer available
8710326020 MOTOR SUB-ASSY, HEATER BLOWER, W/FAN / FJ80, FZJ80 / 01.1990 - 01.1998
Part Number: 8710326020
Supersession(s): 87103-26020; 8710320030; 8710360130
Available in Stock
HEATING & AIR CONDITIONING - HEATER UNIT & BLOWER. 1991 Toyota Land Cruiser VIN starts with 4.0L A/T | Toyota - https://parts.toyota.com/a/Toyota_1991_Land-Cruiser-VIN-starts-with--40L-AT/_72801_6723446/HEATING--AIR-CONDITIONING---HEATER-UNIT--BLOWER/791440-8712.html
Toyota only lists one blower assembly for my VIN, I am going to stick with 87103-26020 (in stock) and assume the other is some overseas model bull****. I'll let you know how it works.
No longer available
Available in Stock
Toyota only lists one blower assembly for my VIN, I am going to stick with 87103-26020 (in stock) and assume the other is some overseas model bulls***. I'll let you know how it works.
The -26020 blower motor is for a truck with no AC. I assume you have AC?
Good luck.
Ok, so I know this is not very useful.. but I swear I replaced mine with a Honda blower motor. (maybe from a civic?)
If I did that, then I got that information from this forum... might help with your searches.
Lools like the four seasons blower motor from rock auto and the OEM blower fan from Toyota combo is the only choice.
Toyota dropped the ball on AC blower motors, all 80's in the states have AC as far as I know.
I don't see that you can get the fan/blower combo from toyota either. Even the complete replacement box that is supposed to contain those parts is NLA according the sites I am looking at. Rock auto it is. May see if I can pull the motor apart when I take it out. If the shaft can be removed you may be able to swap it to the motor for no AC trucks. Looks the same to me except the shaft length.
how did you access that area? Concerned I have leaves and such in mine too since the truck sits outside a lot
I pulled the glove box out and cross bar. I took out the two clips and all the screws for that bottom plastic cover and just pulled down with my finger. That gave me enough room to Shop-Vac off the front of the heater core. It appears the mice got in there at one point. I had twigs inside the fan blades.
