Bought it and it had a high idle.
Replaced for maintenance
Timing belt, wires, plugs, cap, rotor, front main, injectors, valve cover gaskets, water pump, misc vacuum hoses, coolant flush, brake flush, P/S flush, trans filter, fuel filter, intake gaskets and so on................
Still flipping high idle at 1,200 rpm's
Checked the Pot, some screw on the throttle body, AIC valve, installed new coolant temp sensor for EFI, set timing, TPS and so on.......I have given up........Toyota tech friend of mine is baffled.
ideas?
Shane
ideas?
Shane
