1990 LJ73 Diesel
I am sure it can be done and I think Besttop did it before from the pics I saw on here before. This is just my opinion, but I don't think any aftermarket kit out there is going to even come close to the quality and fit of the OEM 73/74 soft top set up. Not even close.
I removed the 4 or 6 bolts from across the top and the 4 bolts along the bottom, remove hinges from the bottom and slide out the windshield surround.
4 bolts along the bottom? Can you elaborate or show pics?
I finished rebuilding my engine. Then all of a sudden overheat. We can check the water pump, radiator cap, thermostat, radiator. Also did 3 chemical test and all came back negative. It leads me to believe that my to 2 things. A bad head gasket or cracked head.
HELP
I have spent tons of money on this truck. NOT ready to give up just yet. But.... It's getting there.
Can any suggest anything.
Yes, you can tell us which engine it is.
And start your own thread in the diesel section if its a diesel.
