Build 1990 FJ62 5.3 and H55
few pics...and I hope to swap in a 80 series air filter huosing this spring
also sprayed some starting fluid around the 2 booster hose ends and around other potential intake leak areas and got no change
man, if you can open up the air inlet on the 80 series airbox to be 3 or 3.5 inches in diameter. Its the air intake choke point. I need to redo mine before i tune it again. Leaving a lot on the table with the factory sized intake hole coming off the side of the airbox can
I cut the top part off and 90 4 inch into it also make the inlet to the box bigger I can say first hand it makes a difference. @onemanarmy it also goes on the passenger side not driver side how you have your intake now.
@tmxmotorsports oh man thats what im talkin about! The LS1 i built right before i moved in the summer hit the dyno and the first thing the guy said was the airbox was restricting it super bad. What you did should clear it right up haha. Im planning on doing something similar to mine
I can't put that huge 80 air box on the passenger side due to the high mount AC compressor on my LS, and tons of wiring
I thought the 'check valve' was part of the nipple on the booster? inside the housing maybe?
is there a seperate check valve on the stock 62 setup?
Few trips with the 62 over the past year..and working on NVH, to the limit possible.
I believe it has the advance adapters LS swap kit, and the puck style engine mounts. Is there an upgrade for these? Mine look collapsed, but haven't taken them apart just yet.
Or is it best to just call AA and get new ones from them?
Thanks!
Thanks!
You would have to change out the entire engine mount the metal parts welded to the frame. Easiest option is to buy another set of puck style isolators from advanced adapter.
Spend one day and cut that junk out and install my kit.
When that time does come around, switch to a log style cast exhaust manifold from your tubular headers. That will make a nice difference as well.
