For Sale 1988 FJ62 11K
Arlington, TX
Hello Guys,
I purchased this Land Cruiser in February of 2015 with 161k miles on the clock. Since then I've enjoyed taking care of this truck and giving it a good refresh. The mileage is currently at 179,796. Over the past two years I've done the following maintenance/base line work. This truck has spent it's life in New Mexico and Texas. Very minor rust pitting is occurring at a few spots at the surface of the original paint. Nothing that can't be sanded out and resprayed. For a Land Cruiser, I consider this one damn near rust free. One minor dent on rear quarter panel (see photo). Interior is pretty clean other than the usual driver seat tear. Dash is cracked. This truck has been my daily driver and runs very well. I'm moving on to another toy now. Big Thanks to this forum for all the helpful knowledge. $11,000 Takes It.
Photos:
https://goo.gl/photos/jko12wFeL1JgZCo47
Here are all of the parts that have been replaced during my ownership:
-New Gear Oil in the Transmission/Transfer Case/Front/Rear Differentials
-Oil Pan Gasket (OEM)
-Transmission Pan Gasket (OEM)
-Timing Cover Gasket (OEM)
-Front Crank Seal (OEM)
-New Radiator (CSF 2708)
-Cap and Rotor (OEM)
-Spark plugs (OEM)
-Plug wires (OEM)
-Fuel Filter (OEM)
-Fan clutch (AISIN)
-New Radiator hoses (OEM)
-Water Pump (AISIN)
-Thermostat (OEM)
-Thermostat Housing Gasket (OEM)
-Valve Cover Gasket (OEM)
-PCV Valve/Grommet (OEM)
-All Vacuum Lines (OEM)
-Intake/Exhaust Manifold Gaskets (OEM)
-Brake Master Cylinder (AISIN)
-Brake Lines (OEM)
-Brake Pads/Shoes
-Brake Wheel Cylinders - Rear (Advics/AISIN)
-New OEM Shocks
-OME Steering Stabilizer
-Knuckle Rebuild Kit (Marlin Crawler/Yukon Seals and Bearings)
-Japanese 555 Tie Rod End Kit
-Air Flow Meter Refurbished by Bavarian Restoration
Things That Do Not Work:
1.) Stock Radio works but the scan button is the only way to get thru the stations.
2.) Stock Antenna is functional but power up and down does not work.
3.) A/C currently does not blow cold. I've had compressor rebuilt and converted to R134. I have purchased the following parts to completely overhaul A/C system. After a 6 month wait, I finally received the Denso condenser from Japan (was on backorder forever). I will have a/c working prior to sale.
HVAC
AC Compressor Rebuilt (Converted to R134)
-New Blower Motor (VDO/Siemens)
-Condenser (Denso)
-Expansion Valve (Denso)
-Evaporator Core (Denso)
-Reciever/Drier (Denso)
-Pressure Switch
-Blower Motor Resistor
4.) Small Oil drip at rear main seal.
Please feel free to IM with any questions or additional photos.
Thanks
