1988 3F LHD A/C Issues
Emerald Isle, NC
I was driving on a hot day at full blast AC and pop noise heard and AC stopped blowing. Assumed it was the blower motor or resistor.
Took down the whole dash, ordered part # 87138-90K00 for new resistor, checked the blower with 12V and works fine.
Tested electrical on the actual switch part# 84660-90K01 (ordered just in case), seems like I get power into the switch, checked all fuses and they are OK, but cannot get a read to the resistor or blower, so I assume there is a relay of some kind that I can't find.
Disassembled the entire dash looking for a Relay, checked on available electrical diagrams, but no luck.
Need some community help to get the actual electrical manual for a similar FJ70, don't have the legend for the fuse box located on driver side. No other fuse box found elsewhere.
Any advice or experience will be helpful...
Thanks,
JZ
Pics always help
Photo of fuse box?
Could be a circuit breaker on the fuse panel.
Fuse Box
Well well
Believe it or not. Touching that breaker above the fuse panel made a clicking noise and after that current tester starter showing voltage.
All speeds of A/C work now.
Thanks guys, you always come through
Thanks jblueridge and rhino
