SOLD 1987 Toyota Pickup Xtra Cab 4x4 SR5 22RE 5-speed Manual Factory A/C St. Louis, MO
Status
Not open for further replies.
Missouri
Year
1987
  1. Minitruck
Mileage
264411
Color
Blue
Selling my 1987 Toyota Truck.
Xtra Cab, 4x4, SR5, 22RE, 5-speed Manual, Factory A/C
$18,500
I have had the below work completed on the truck in July/August 2019 and have only put on ~1,000miles.
Top end was rebuilt under previous ownership within the past 5,000miles. Located in St. Louis, MO.
~264,xxxmiles
New clutch assembly
New clutch slave cylinder
New clutch master cylinder
Resurface flywheel
New rear main seal set
New Brass/Copper Radiator
New rear brake shoes
New rear wheel cylinders
Resurface brake drums
New front brake rotors
New front brake pads
New brake master cylinder
Flushed brake fluid system and replaced with new fluid
New hub gaskets
New axle seals
New idler arm
New shock absorbers front and rear
New steering stabilizer bar links/shock
New sway bar links
New transmission input seal
New transmission output seal
New differential pinion seals
New spark plugs
Compression test
New PCV valve
New air filter
New fuel filter
New exhaust system
New muffler
New antifreeze
Cooling system flushed
Installed a hidden kill switch
Replaced gear oil
Replaced transfer case fluid
Oil change
New oil filter
Bearings greased
Lock out hubs cleaned and lubricated
New belts (3)
Converted A/C to R134a
Added refrigerant
New radiator cap
New wiper blades
Undercoating applied
Spray-in bedliner
Windows tinted
Upholstery items addressed
Custom front mats
Happy to answer any additional questions on the vehicle. The videos and pictures show the quality.
Status
