1985 HJ75 Pickup
Onur can probably sell you enough parts to just build one of those fancy 79 Series and you won't have to settle on an old 75 Series. :D
I stopped in on Onur yesterday with some old truck I picked up, he's probably ready to cut me off by now.
At least with that one you've got, all it needs is to change out those gocart wheels
I drove this one for a while, mostly while trick or treating. I think that "powerful" diesel is the sweetest.
DELUXE go cart wheels..... :D
Even the dogs needed an afternoon nap after a large Thanksgiving meal. :)
Hope everyone had a safe and enjoyable holiday.
Am I overlooking the obvious?
Does the rear window washer have it's own activation switch or does it spray when the front ones are activated?
When you figure it out let me know. I've tried holding switching and all of the above. Can't seem to get mine to spray.
Edit. Mine just clicks to on or the wiper on no option to hold.
Nigel you should have sent me a p.m. ...... now we both appear stupid. :D
I'm ok with stupid. I've been trying to figure the bloody thing out since I've had it. I assume you figured it out.
"I assume you figured it out" .......... NO......... No I have not!
All I have managed to do was either activate the front wipers, spray the front glass or both. :)
I know with the headlight washers you kind of have to know the code to get it to work. Headlights on, tap the headlight sprayer once then hold the second time for headlight spray.
wiper switch on dash, hold it in
The wiper stick moves "up and down" to control the wiper speed and pulls aft to activate the windshield washers but does not move "in or out". Perhaps I am overlooking something simple which would be kinda ironic since my wife often calls me a simpleton. :D
It pains me to admit you were right but I will. :)
I'm embarrassed to admit its kinda self explanatory if you actually look at the switch. Even though I had used the switch dozens of times, I had never really looked at it. :)
Nifty little switch .......
In case anyone has a different switch, this is what mine looks like. Charles was trying to help me trouble shoot mine and I will try some different techniques tomorrow. Mine seems to click and stay in either position. I shall attempt to push it past the click and see if there is a spring that goes further as Charles mentioned. Will report back.
see the side of the switch that has the squirter symbol and the line? the line points towards the side that is intermitent AND the squirter if you push just a wee bit harder.
i know, rocket science for a Yank ... common sense for us Canucks.
<okay, that was a bit harsh>
