1985 Banana Buggy (slow build)
Shreveport, La
A few months back I picked up a 1985 pickup. Everything stock except the suspension. I'm a mild weekend warrior and at the moment I'm driving my truck to and from work (10 mile commute once every few days). Ride quality and on road drivability are for the birds. I'm going for a fully cabaple rig and an eventual trailer queen when I buy a tow rig. But until then, this is how she sits
-1985 Toyota pickup (mar. '85)
-stock straight axles f/r
-5" ish spring lift with 12" BDS shocks
-22re (187xxx miles)
-a340f auto trans. W/ manual valve body swap
-stock gears and axle innards
-stock steering components except lifted drag link
-15" rims
-33x12.5 BFG t/a KO tires
Anything else I didn't list is probly stock or insignificant at the moment. This is a build thread but also a suggestion thread. Thanks for checking it out and any posts or suggestions are appreciated.
Also follow my rig and adventures on Instagram at https://instagram.com/bananabuggy12/
Or @BananaBuggy12
Thanks!!!
I'm jealous of the 22re and a340f tranny combo. I had a 22re and a340H and man you have no options because of the T-case. Gear looking rig!
Thought I'd update.
Ive found an IFS steering box for a decent price from an '87 that I'm ordering Monday and start collecting the parts for my HI-steer conversion! Baby steps!
I've recently found signs of on oil leak... Not on my list of things I wanna do right blnow but I'm gonna start hunting it down. Doesn't look recent. And my oil levels since the oil change last week haven't changed,that I've noticed. Anyone have any suggestions?
Oil is splashed all over the bottom of the engine above the oil pan, on the pulleys, and around the valve chain cover. Majority of it is near the front of the block.
I checked the oil pan bolts today. All good. I'm gonna spray it down with some brake cleaner and clean it out. See if I can find the exact point.
Its dark outside bow so I'll get some pictures tomorrow if I don't have to work.
This is typically caused by a groove being worn in the harmonic balancer where it rides on the lip of the seal. The seal is installed into the oil pump. I hear about speedi-sleeves but I'm not a fan of them, seems like a bandaide fix to me. Another option is to get a new balancer, you can find them on eBay for ~$100 (don't buy a used one).
When I took my engine out I was plagued by a chronic leak at this seal, and I had a groove in the balancer. What I did was make a spacer out of a piece of 16-ga aluminum that I used to press in a new seal, which pushed the seal a little deeper into the oil pump, so the lip rides at a different spot on the balancer. No leaks whatsoever after 5000 miles, so I guess it worked.
Get an OEM seal.
