For Sale 1982 Toyota Pickup Rock crawler
Year
1982
  1. Minitruck
Mileage
80000
Color
Orange
Outside Link
https://sfbay.craigslist.org/sby/cto/d/sunnyvale-1982-toyota-pickup-rock/7299607215.html
1982 Toyota 4x4 Pickup Rock Crawler. Fully built custom rock crawler. Licensed & street legal. Won "Best in Show - People's Choice" and "Best in Show - 4x4" at Cal4Wheel Convention in Sacramento. Walks through the Rubicon and Fordyce without breaking a sweat. One of the cleanest and best-equipped rigs on the trail.
- GM 4.3 V6 w/ 700R4 auto transmission (California smog legal; just passed smog on 3/20/21).
- Dual transfer cases
- Dana 60 hybrid rear axle with ARB air locker, 5:38 gears, Yukon chromoly shafts & disc brakes
- Dana 44 front (thick-tube model out of Jeep Wagoneer) with ARB air locker, 5:38 gears, chromoly shafts, CTM joints, Warn hubs, High-steer with ram assist, 1-ton tie rod ends, HD pitman arm & disc brakes.
- Lokar shifter
- Transmission cooler
- Currie Anti-Rock swar bar
- Travel master front drive shaft
- CV rear drive shaft
- Double triangulated 4 link rear suspension
- Rancho 44044 front springs
- Bilstein shocks (front & rear)
- York on-board air
- Warn 8,000 winch
- Full cage
- Custom bumpers (front and rear) with tire carrier
- 17 in Raceline bead lock rims with Goodyear MT/R tires (38/14.50/17)
- Spare tire (Goodyear) with carrier
- High lift jack
- Full set of Autometer gauges, including tach
- Under-carriage trail lights
- Dometic fridge slide
- CB w/ antenna
- Sony stereo, amp & 4 speakers
- Full set of trail spares (rear drive shaft, front leaf spring, rear axle shafts, front chromoly stub shaft, CTM u-joint, ball joints, Warn hubs, driveshaft u-joints, wheel bearings, seals, fuel pump and more)
$25,000/obo. You could easily spend twice this much trying to build this truck.
See Craigslist add for pics
Call Nick at 408-439-9153
@Pacer ... stop it, you don't need this. I need this to keep up with you and Andy.
