Sheesh, Chris, that is a beautiful truck. Would love to drive down and see it, but that temptation is the last thing I need! GLWTS!1982 TOYOTA FJ40 LAND CRUISER
Power Steering
U.S. Version
Background information: Purchased new 7/31/1982 at Seminole Toyota Tallahassee, FL. This Land Cruiser came with a certificate that states: FREE OIL CHANGES FOR LIFE OF THE CAR (except… the dealership is no longer in business). I am the third owner. Second owner who I bought it from purchased in 2010 from original owner family. It is a US Version Land Cruiser which makes a huge difference in comfort, safety, and value. The truck has been driven to FJ rallies in NC With No issues.
** BODY CONDITION **
Due to the exceptional care by the previous owner, rust was not a factor with this vehicle. It was repainted piece by piece using factory OEM Medium Blue (color code #857) in base coat clear coat. Top, front grill painted OEM Cygnus white. Previous owner added correct stamped new front floor pans. No other panels or rust repair was needed. New OEM Parts: front bumper, bumperetts, mirror arms & mirrors, door weatherstripping window sweeps, door pins & bushings, license plate lights, ambulance door & side window weather stripping, emblems, hardtop weatherstripping.
.. Rubber pads custom made under all painted hinges (no paint to paint).
** 245 hours of professional paint work was recorded with $3,000.00 of primer & paint.
** INTERIOR CONDITION **
All seat upholstery (new foam on front seats), headliner, and have been recovered. Sun visors are new OEM. Front seat frames & roll bar have been powder coated. Dash is original with no cuts or tears. Original Toyota mat with Lloyd custom mats over top. Under mats is custom sound deadener (not glued in). All dash controls, gauges, and lights in working order. Jump seats and new seat belts in place. OEM tool kit, spare tire jack, and rods in original mountings. Brake and clutch pedals powder coated.
** MECHANICAL CONDITION **
4.2-liter 2F inline-six (90,328 miles) linked with a four-speed manual transmission and a dual-range transfer case. POWER STEERING. Head and valves rebuilt by Precision Crankshaft in Jacksonville, FL. Manifolds reworked and new OEM manifold gasket, exhaust manifold rings & springs installed. The transfer case was rebuilt, Transmission resealed. New complete clutch assembly. Jim Chenoweth rebuilt carburetor. 5 new 16 inch powder coated wheels from Cruiser Outfitters with Yokohama Geolander AT’s 235/85/16. Alignment. Old Man Emu springs, shocks, shackles, greasable pins, steering dampner.
All splash shields, oil pan, valve cover, thermostat housing, air cleaner, sand blasted & powder coated. New spark plugs, wires, distributor cap, rotor, hoses, belts, Battery, rear main seal, emergency brake cable, front brake calipers & pads, power steering pump, air pump, tie rod ends, Wheel alignment. Brake fluid flush. Alternator rebuilt.
Everything works..Including seat belt buzzer and cooling fan. New coolant & washer reservoir with new washer motor. LED instrument cluster bulbs making it bright and easy to see gauges.
** Documented Maintenance Receipts $9,608.35 (not including paint)
02/11/2013 90,259 Aaron’s Car Care Jacksonville, FL
Parking brake cable $79.10 labor $53.10
Brake pads & hardware $114.90 labor $ 97.35
Power steering pump $503.48 labor $221.25
Drive Belt #1 $55.05 #2 $28.50 #3 $12.50
Power steering flush $30.66 labor $44.25
Air injector pump $387.46 labor $78.65
Front caliper pair $145.96 labor $141.60
Wheel alignment $89.95
Brake fluid flush $6.85 labor $44.25
Customer supplied tie rod ends labor $115.05
Customer supplied rear brake cylinders labor $132.75
Overhaul alternator labor $177.00
08/29/2013 Rocky Road Outfitters
Old Man Emi Suspension $2604.00
Front spring pair CS001F
Rear spring pair CS001R
Greasable pins OMEGP8
Rear shackle pair OMEGS1
Front shackle pair OMEGS2
Sport shock front pair 60097
Sport shock rear pair 60032
Bushing kit OMESB1
Steering damper OMESD23
09/05/2024 Toyota of Newnan
Power steering rebuild kit $169.03
Rag joint $91.20
Front door weatherstrip pair $264.20
Rear door weatherstrip pair $192.33
Apron emblem pair $101.24
09/11/2024 Toyota of Newnan
Manifold ring gaskets (4) $90.84
Manifold spring gaskets (4) $49.32
Manifold gasket $47.02
09/30/2024 Flintstone Hot Rods
Rebuild power steering gearbox $175.00
10/16/2024 Toyota of Newnan
Fuel filter $8.54
Rear door window weatherstrip pair $56.36
Rearview mirror $95.75
Defrost clips (8) $25.04
Hood support grommet $5.95
10/14/2024 Specter off Road
Headliner $192.25
Front seat foam pair $519.00
Headlight inside bulb $3.95
10/12/2024 Cool Cruisers of Texas
Door regulator left $49.95
Door hinge pins & bushings $12.41
Corner reflector pair $38.74
Hardtop pole weatherstrip pair $14.20
Windshield wiper blade pair $12.95
Kickoff vent weatherstrip pair $10.25
**** Vehicle ID# JT3FJ40C2C3353453
Clear Georgia Title licensed and registered in my name. Frame stamped number, firewall plate, door pillar plate all match title.
Pictures before, during, and after restoration can be seen here:
1982 Blue Jacksonville, FL - Chris Wade
Thank you for visiting my site Contact: wadesters@bellsouth.net 404 819-6943chriswade.smugmug.com
***AS DESCRIBED THIS FJ40 IS STUNNING AND TURNS HEADS WHEREVER IT GOES. THIS YEAR MODEL IS VERY RARE AND SECOND TO THE LAST IMPORTED. ONLY A VERY FEW CAME WITH POWER STEERING OPTION. COMES WITH SOUGHT AFTER 3.70 DIFFERENTIALS AND FACTORY 22 GALLON FUEL TANK. HARD TO FIND IN THIS ORIGINAL RUST-FREE CONDITION. LOCATED JUST OUTSIDE OF ATLANTA, GEORGIA. $74,000.00
