SOLD 1979-85 Toyota Truck 4X4 Power Steering Gear Box
Status
Not open for further replies.
kevos37
Supporting Vendor
Sutter, California
I have a couple Toyota mini truck steering boxes for sale, both work smoothly. $225.00 (each) priority shipped and insured to your door. Comes with pitman arm if you need it. Accept PayPal.
Thanks
Kevin
I"am in North Carolina is this best u can do on price ? u help me out some on shipping ? Thanks for considering
Shipping costs are included in the $240. The little things are heavy, I use a USPS flat rate box or it would cost another $25 for shipping.
Kevin
Are these off of 4wd trucks and do they need to be overhauled? Thinking about doing FJ40 power steering conversion with JT Outfitters power steering kit. Any advice would be great.
This is the correct box for the application.
I would recommend a seal replacement as a minimum .
There are several different vendors that offer parts to accomplish this task. I personally have used orangefj45 (Georg is a vendor on Ih8mud ) I have found his prices to be fair and his knowledge on FJ40's to be indispensable. He also has a great "Service after the Sale" ethic second to none.
I hope this has helped.
Kevin
So are these units only for power steering conversion? I currently have a RHD hj47 with manual steering. It desperately needs an overhaul but considering power steering.
Does orangefj45 have man st rebuild kits?
Thanks
J
These units will work with LHD FJ40's. Since the pitman spline is the same, and with the box mounted on a new pedestal, everything remains basically the same. Without the need of major modifications.
As for a RHD I can only assume the box output shaft is opposite.
I did not understand your last question about Georg.
Kevin
Thanks
J
Sorry, I did reply directly to your questions. but I did indirectly above.
Yeah i guess i could have said that better. Do you think he has gasket kits? Or whatever is necessary to overhaul a steering box
Thanks
I do not know if currently stocks a gasket kit. I would assume L&R kits would interchange. But you can ask him, just look for Orangefj45 on Ih8mud or contact him at -
Georg @ Valley Hybrids & Cruiser Brothers
Cell 650-576-2023
Kevin
One left, $240 shipped to your door.
Kevos, do you have the return line fitting? I have three from different sources and they are all too big. I've heard that the mini truck boxes had a small and large return fitting depending on the year.
I think this is what you are looking for.
Larger and smaller fittings.
Status
