1978 FJ40 Patina Restoration
Augusta, GA
Just started a restoration on my great grandfathers 78 FJ. It was not in my possession the last 20 years or so and has been neglected. It is a great candidate for a patina restoration though. Do yall have any suggestions for the paint? I was thinking about using a light cutting compound and then a ceramic coat to lock in the patina and bring a little shine back to the paint.
T think there's a product called "Poppie s Patina"", used by hot Rodgers. Spray or even brush on. Comes in gloss, matte or flat i think. Clean/sand/prep surface and apply. Seems to last at least a few years, but most of these cars are garage kept.
Welcome to the site. Looks like you have some work in your future. Folks approach this in several different ways. I've deep cleaned the surface and maybe some color back or rubbing compound. Maybe check out the thread below can help. Maybe start at the end and work backwards or not.
Wow, what a cool cruiser! That thing should absolutely be preserved. Its in way better condition than the 1978 Freeborn Red Im trying to save!
Id read that thread mentioned above. It may be mentioned in there, but another thing Ive heard that you should do in this situation is to kind of condition the paint before you start putting any sort of rubbing compound to it. Basically Id start by pressure washing it, but not too strong, then just hand washing it with some good car wash containing carnauba wax. Hand wash a few times. Then from there just start compounding it. Im just using basic Turtle Wax rubbing compound for heavy oxidation, doing it by hand one section at a time, and its working well on my original sunburnt and stained Freeborn Red.
Whatever you do, dont let anyone talk you into painting it!
What do you think about a ceramic coat? I've heard turtle wax has a good spray on ceramic.
wash woth water, little bit of dawn and red, cotton, shop rags, 2 or 3 times until all the loose color quityes comin off. Then a coat of fluid film, rub in decent amount, let soak in and dry. Then I would use a spray & wipe Mequires (sp). I use theirs that sprays on, drys super quick then buff off by hand with same red shop towels.
Fluid film didn’t last long in mine. I’m polishing now, and then will wax or seal. A buddy do zap floor polish on his original paint / patina’d CJ5 and it retains its sheen and cleans up easy enough.
I have only used Fluid Film on my chassis. It seems to protect the undercarriage from rust and makes cleanup easier after offroad in the mud and mess.
So you go straight from handwashing with shop rags and Dawn to Fluid Film with no compounding or anything else in between?
The fluid film on the paint -- if your paint still has clear coat or some shine the fluid film will more or less stay on top and wipe off, BUT -- if you have chalky paint that comes off on the rag, rust divets, layers of paint, & not auto paint, jackass rattle can stuff thats all patinaed to heck then that fluid film soaks in and brings some life back into the paint. Maybe Wngrog was messing with me when he said, " Yeah, put it on everything" but I did and so far so good.
If my truck had some sort of paint job I would probably try to compound or sand/polish some life back into it but I have a rattle can camo job that was put on the 40 for a hunting rig in the finger mountains of CA 40 years ago so not much to compound or polish.
Never thought of using Fluid Film over a paint job. I do use it on my chassis and suspension. Makes clean up easier, or so it seems.
I'm going to be that guy: I vote for stripping the windows and trim, smoothing the dings and dents, epoxy prime and paint. Then new weather stripping, window rubber, lights and emblems.
Then put all the old parts into a 'patina bin' for Wednesday pickup at the kerb. This will allow you to drive this rig as much as your want in any weather. Use it like it you bought it new and then in 20 years, 'preserve the patina' again the same way.
Many 'patina' rigs are not driven daily or even regularly. Before 'patina' was called patina it was called 'neglected'. This rig is too nice to be left looking like it was neglected, and it isn't 'pristine' (different from 'patina' in that it means it was stored indoors and well-cared for) enough to save for posterity.
Just my 2 cents.
Mine was not quite as patinaed as yours, but I started with a good wash with a brush and soapy water. then used a bit of soap and perhaps 10% vinegar solution and a Mr Clean Magic pad - that really cut the chalky paint, and surface rust, then washed it off again and went over it with a polishing pad and carnuba wax. After that, your favorite ceramic coating, and it should last a good long time.
