Can anyone tell me where the external resistor on a '78 is located and what is looks like? I would like to test it. Thank you in advance for any info.
The pink wire in the link pic I gave {I thought it was brown] should be the wire.
You may have to trace it back to the ignition switch {is that where it goes?} to test it's continuity, and check the ignition switch is ok as well, to make sure 12v is getting to the wire.
‘78 has a 10ga PINK Yazaki resistor wire in the main harness. IIRC it starts around the Fusible Link connection point, on the passenger side or the battery positive terminal, and runs to near the Choke Pull Switch, behind the dash.
The Yazaki replaced the Ballast Resistor in ‘78.
It's the one connected to and above the black and yellow wire. It looks kinda very light pink, almost whiteWell, I looked at the photo and not seeing a pink wire. I'm I missing something? Thx again
thank you again. I will check it tomorrow. What is the difference of a resistor wire and ballast wire? Are they not the same?In this pic 73 FJ40 ignition wiring [just an example, coz I assume yours is a column key?]
The b&y wire should have 12v when the ignition is on.
If it does, but the coil still has no volts, there is problem somewhere, like a break, or a fried ballast wire. Unless there's a fuse or relay between the switch and the coil?
If the b&y wire has no volts when ignition is on, there is another problem with the switch or fuse etc.
Your 40 *should* have a b&y ignition /coil wire connected to the switch. It needs 12v in the on/run position regardless of the type of ignition switch.
Yes, sorry, they are the same.What is the difference of a resistor wire and ballast wire?
If you are referring to the main engine fuse near the coil, yes. Also checked the coil fuse in the fuse box. Both goodYes, sorry, they are the same.
Also , I assume you tested the fusible link?
I've haven't seen a fusible that looks like that. I will definitely look for it, if I can find it. Thanks so muchI think your 40 fusible link should look something like this Fusible link and fuses issue
And afaik it's near the battery. Or not.
Someone will know more about 40's fusible links.
