1976 fully restored FJ40 for sale in OR.
This is one of the nicest ones around.
$34,000.00 obo
Ebay listing . http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=220135430955
Frame
Stripped down to bare frame, sand blasted & refinished semi-gloss black
Engine
Rebuilt 383 stroker engine Built by MidWest Motorsports http://www.midwestmotorsportsinc.com/order_part.php?item=SP383SBF&line=MWM
New Dist
New starter
New alt.
New water pump
New pulleys.
New manifold
New heads.
HV oil pump
HV oil pan.
Custom radiator
New block hugger headers.
New wires.
New cap and rotor.
New Battery cables.
New Optima battery.
Rebuilt 350 turbohydromatic Trans
Powertrain
Rebuilt front and rear drive lines.
Overhauled Toyota transfer case replaced all seals & bearings.
Overhauled front end & rear axel. replaced all seals bearings.
All components were cleaned and repainted.
New complete custom exhaust system
Advanced Adapters engine and trans mounts. http://www.advanceadapters.com/
Cooling
New custom made radiator
New water pump
Replaced all lines & hoses
Heater cores flushed & pressure tested
Front and rear heater units repaired & refinished working perfectly
Brakes Refurbished the factory power brake system
New mastercylinder
New wheel cylinders and calipers.
Cleaned and refinished all valves,lines & booster Front disc Brakes & rear drums rebuilt.
Whole system checked & rechecked
Steering & Suspension
Added GM Saginaw pwr steering system
Tie rods replaced All front end componets replaced or checked, cleaned & refinished
New steering dampener
All new OME shocks
Old Man Emu leaf spring package.
Steering correction kit added creating a small lift apx 2 inches
Professional front end alignment
Interior & Electrical
Reupholstered front bucket seats & rear jump seats
All seat frames sand blasted & refinished.
All seats proffesionally re upholstered factory color.
Roll bar sand blasted & re finished with factory pads
New headliner
New OEM dash pad
Floor coated in sound deadening & chip resistant material that is color matched.
New OEM sun visors
All gauges, warning lamps & controls working perfectly
Wiring harness disassembled tested, repaired as needed & rewraped
New seat belts.
Body & Exterior Removed from frame & disassembled
Metal dipped to remove rust & paint
No panels were replaced, all original floors and tub.
Door skins separated from shells rust removed, rewelded & rustproofed
Grille bib disected, sand blasted, rewelded & rust proofed
Cowl discected, s/b, rewelded, r/pd' All componets of removeable top disected, s/b, welded, r/pd'
Tub disected as nessesary s/b, weld, r/pd'
Top rain gutter removed from roof and treated
New OEM fenders
All nuts & bolts have been coated, many are new Toyota.
All weather stripping replaced with new OEM
All body bushings replaced
New rear bumperetts
Brand new OEM emblems & badges
Undercoating applied while a bare tub
All new OEM lamps (turn signals,tail lamps ect)
Fiberglass top repainted All paint work done with quality PPG products in a heated down draft booth Colors are based on factory Toyota paint codes (freeborn red)
Wheels & Tires
New OEM wheels powdercoated to original colors
New OEM hub caps 5 new 33x9.5x15 Super Swamper TSL's Options ARB front bumper http://www.arbusa.com/index.php
Old Man Emu suspension http://www.arbusa.com/emu_dakar_leaf_springs.php
Warn 8274 Self recovery winch. http://warn.com/truck/winches/src/M8274-50.shtml
IPF driving lights http://www.arbusa.com/lights_driving_fog.php
Braided brale lines
Bass tube under drivers seat.
Alpine CD-IPOD-AM-FM with wireless remote.
Amazing!
it looks incredible! I thought you might want to know that a couple of your fototime pics are of a bird and a tree, 20 and 21! :bounce2: Would you mind telling me how much the front ARB for a 40 runs?
Yes that little woodpecker was talking up a storm behind me while I was taking pictures. So I hid behind some brush and snappen that pic when he popped up.
Arb bumpers are about $800 I believe.
BTT for a nice rig.
You sure those aren't actually 33x10.5x15?
Good luck with the sale :beer:
Hummmmmmm I am pretty sure, but I can't swear it.
