- Location
- United States
SOLD
Up for sale is my 1976 FJ40. Located in Eastern NC, about 45 minutes NE of Jacksonville.
For the purists out there, shield your eyes.
Time to trim the stable down to free up $$$$$ and garage space for new projects to work on. I’ve had it for about 5 years and have had a great time restoring it and expanding my mechanical skills. It has some of the looks of an older 40 with the mechanical benefits of a newer one.
Originally started out as a hard top, but an altercation with a tree bent and cracked the fiberglass cap, I decided to go soft top. I opted with the vinyl versus the canvas top, and it has held up great thus far. The OEM soft doors turned out real nice and keeps that old school look.
Starts and runs fine, but the fuel drains out of the carb if you don’t drive it for a week or two and you have to hit it with starter fluid every now and then to get the bowl primed. Steering is tight and straight, a little wobble at 45-50ish but no death wobble.
The only known mechanical issue aside from the having to prime the fuel system now and then is an oil leak at the front main seal. I had to replace the oil pan due to the skid plate rusting out and oil leaking statically from there, and was pretty sure that was the source of the leak. Turns out additionally it was the seal behind the mail pulley on the timing gear cover. It doesn’t leak statically, only when the truck is running. Good thing is the underside of the truck is well lubricated and probably won’t rust, ever
I do have a seal and Speedi sleeve for the crankshaft, I just haven’t had the time to pull the front end apart again to replace it.
Body wise, no rust on the body as most of it is aluminum, and only a little surface rust on the frame underside that I have been stripping, treating and coating as it pops up. When I leaned into the tree that cracked my hard top, the drivers side also has scrapes in the paint down the side and a couple of small dents in the aqula tub in the rear quarter panel. There is also a crack in the paint and primer right behind the fender where the front cowl flexed a little. The PO also drilled a hole to fit some goofy aftermarked antenna that was falling off when I bought the truck, I relaced it with a Firestik antenna mount which covers up the carnage the PO left behind. Also, the PO tried to do some type of gauge modification on the dash, do there was a big boondoggle hole between the gauge cluter and all the dash knobs. I had a piece of stainless steel painted and now completely covers the abortion of a hole. And there are the usual scratches and chips as this truck is not a garage queen.
The interior is really nice, it is fully carpeted with a set of shane’s seat covers that really brought the interior back to life. The DS seat has the extension bracket installed, so you tall guys will have a little extra room. The jump seats were fully restored with new hardware and canvas straps. There also is herculiner all thru the interior under the carpet. I put in all aftermarket Autometer gauges with a custom stainless cluster and matching glove box door. With the Sag PS, I also s***canned the 16” behemoth steering wheel and got a Grant 14” wheel.
Mechanical:
2F with 94600 miles, rebuilt approx 12000 miles ago.
Stock 4 speed and TC
DUI dizzy with Vac advance
DUI Hotwires
New plugs, filters and mechanical fuel pump
Aisin Non-USA carb
New belts and hoses
New aluminum radiator
MAF 2 piece headers and exhaust
Saginaw power steering –w- GM pump
OME 2.5” lift with anti-inversion shackles
4+ U-bolt flip kit F&R
New large pattern knuckles and arms.
New front bearings and races, seals on the recent re-build
New TRE, relay and tie rods
SSBC 4 piston calpers
Brembo drilled and slotted rotors
SS extended brake lines
Longfield Birfs and shafts
Aisin hubs with Longfield spline
New Oil pan and gasket
70 series rear drum brake FF axle
80 series diff converted with Downey’s cable actuator
Poly Performance chro-moly axles
New Autometer gauges and senders
F & R heaters work with new heater valve
New turn signals, markers and Roundeyes headlamps
New reman alternator
Mean Green gear reduction starter
Body and chassis:
Aqualu tub and tailgate
New OEM fenders
Ehsan off-white vinyl soft top and bows
Fully refurbished OEM soft doors with new lexan windows
Hawkdriver winch front bumper
Old school CCOT Safari rear bumper
Tire and dual can carrier rack
5 x OEM powdercoated steelies and hubcaps
New Interco SS TSL radials in 31/9.5R15
Aatlas1X replacement vinyl for front and jump seats
New OEM seat cushions on front bottoms and all jump seats
Tuffy console
4+ rocker guards
Con-Ferr toolbox on the driver’s side for the jack and spare fluids
New fender and grille emblems
Included is also the 2F and chassis FSMs and some other stray service pubs.
It has a lot of great upgrades and I definitely in the negative when it comes to what I am looking to get. But, I know that it’s tough times for selling toys and is a buyers market. That being said, I’m not going to give it away either, I am under no pressure to sell, other than the wife complaining that I have too many projects going. I have money and plenty of cruisers to occupy my time, so please no trades or low ball offers.
Looking for $9500 firm.
Any questions or if you want more pics, PM me your e-mail address
I do have a seal and Speedi sleeve for the crankshaft, I just haven’t had the time to pull the front end apart again to replace it.Body wise, no rust on the body as most of it is aluminum, and only a little surface rust on the frame underside that I have been stripping, treating and coating as it pops up. When I leaned into the tree that cracked my hard top, the drivers side also has scrapes in the paint down the side and a couple of small dents in the aqula tub in the rear quarter panel. There is also a crack in the paint and primer right behind the fender where the front cowl flexed a little. The PO also drilled a hole to fit some goofy aftermarked antenna that was falling off when I bought the truck, I relaced it with a Firestik antenna mount which covers up the carnage the PO left behind. Also, the PO tried to do some type of gauge modification on the dash, do there was a big boondoggle hole between the gauge cluter and all the dash knobs. I had a piece of stainless steel painted and now completely covers the abortion of a hole. And there are the usual scratches and chips as this truck is not a garage queen.
Mechanical:
DUI Hotwires
Aisin Non-USA carb
New belts and hoses
Body and chassis:
New OEM fenders
Tuffy console
4+ rocker guards
I gotta take the pressure washer to it
