SOLD 1974 FJ55 Columbia, SC
Status
Not open for further replies.
Irmo, SC
Year
1974
  1. 55 Series
Mileage
62000
Color
rgb(0, 204, 255)
Asking $24500 OBRO.
If you are looking for a mechanically right, reliable, ready to drive example then this should be on your list. I want to be as transparent as possible so I am happy to provide additional images, running videos, repair invoices, as well as answer any and all questions.
Located in Columbia SC
803-608-6920
1974 FJ 55. Runs and drive great with no known mechanical issues. 4x4 works great, starts and drives with zero issues. No leaks. Just had $6000 worth of maintenance/mechanical repairs completed at Toyota in the last 6 months by master tech. Invoices available
All mechanical work performed by Toyota Master Mechanic
Battery Cables, Brakes, Carb re-jet, Clutch flywheel (resurface), Clutch pivot bearing, Clutch disk, Clutch pressure plate, Coolant block drain, Differential fluid change , Engine side cover inspection gasket Extensive interior Cleaning, sand interior floor, rust preventative interior floor, roll in bedliner, Fuel hoses (All), Fuel Tank removed, inspected, cleaned, and sealed,, Head gasket, headlights, Lifters, Manifold exhaust leak, New door cards, new headliner, seats recovered, Oil and filter, Oil dip stick, Oil Drain plug, Oil pan gasket, Oil sending unit, Output shaft seal, Parking brake adjustment, PCV valve and grommet , Pedal pads (Clutch, Gas, and Brake), Plug wires, Plugs, PTO Cover Gasket, Radiator Flush and fill, Rear main seal, Rear power window gear, Rear toe hooks, Rear window seal, Replaced missing window crank and door handle insert, Rings, Seatbelt bolts, Transfer case inspection and fluid change, Transfer case shift boot, Transmission clean and fluid change, Transmission inspection cover gasket, Transmission shift boot, Transmission top plate gasket, Valve Adjustment, Valve cover gasket, Wipers. Original floor mat present with small hole on drive side. I am sure I have left something out…
NEEDS
Odometer is sticking…10ths rolling neeeda to be removed, cleaned, and reinstalled (currently reads 62xxx actual mileage would be higher). This is a common issue due to age. There is a great DIY thread here on mud to resolve.
Some rust in drip rails and a few other minor spots. Also small rust spots on drive and passenger rear quarter just behind wheels, and two spots on rear tailgate lower driver and passenger corners. Rockers, floor, roof flat, and underside is essentially rust free. Due to common fuel system over pressure issues there is a fuel stain under the fuel filler cap. This happens with previous owner. I had the issue one time prior to tank removal and cleaning and replacement of all fuel hoses. I have resolved the issue and it hasn’t happened again.
All exterior lights in working order, but there is an electrical gremlin that is effecting the blinkers. Will not blink when head lights are on. Could be a relay, but I haven’t had a chance to work it out yet.
Status
