I think the simplest way to do this is to take off the exhaust pipe directly below it and put my finger up there to see how the flapper is aligned. Know if I want it straight up or at a slant to prevent the cracking people are talking about?Do not remove the flapper … keep it in to divert the exhaust from under the manifold
What manual is this? My dad said there was a manual in the truck but the mice ate it.Check paragraph 4 in section 15 intake and exhaust manifold. Your tension on the bi-metal coil spring may need adjustment. Also your counter weight stopper, item I, is stamped with a C and H as a guide. See attached.
