Trade 1971 FJ40, Fuel Injected 350, SPOA, Roll Cage, 37 inch MTRs, ect!!
Hey guys, I recently bought this rig from Florida. Its sitting in my garage now in Mitchell, Manitoba. I would love to keep it, but don't have enough cash to do so.
$6000 obo
[URL="http://i1147.photobucket.com/albums/o557/wheelsandwater/IMG_0332.jpg"][/URL]
[URL="http://a6.sphotos.ak.fbcdn.net/hphotos-ak-snc7/163368_10151754867910262_554073125_n.jpg"][/URL]
Engine / Powertrain
Rebuilt 5.7L Gm 350 with 85K +/- with stage-1 TBI fuel injection
RV Cam
Edelbrock performer intake - (All new fel-pro gaskets)
Rams-horn exhaust manifold - New Gaskets - Walker crossover exhaust - 2.5" Single exit with 50 series Flowmaster
Full billet aluminum pulley system
Fabricated aluminum valve covers
Replaced long water pump, alternator, power steering pump in last 200 miles
PSC power steering lines to Saginaw power steering system
New Battery - mounted underneath pass. seat
New starter
New USA-built Sanderson aluminum racing radiator
Taurus Cooling fans - Adjustable thermostat
Fuel Injection
Rebuilt TBI - Every single sensor is new:
AIC, Temp. sensor, knock sensor, oxygen sensor, throttle position sensor, electronic spark control module, etc.
Professionally built TBI harness
15 gal. RCI fuel cell with sump
Stage 1 pro. tuned chip - Runs on reg. pump gas
Brand new GM ECU with new chip
New E2000 Fuel pump / filter
New coil
New Distributor - new cap, rotor - 8mm Wires, AC Delco Plugs
New fuel pump relay and fuel injection relay - ECM, relays and ALDL connection is all in the "glove-box"
Transmission / Transfer-case / Axles / Suspension
Sprung-over - Kept flexy and low as possible for a fj40 w/ 37" tires with a front shackle-reversal
Sm465 - with granny-low first
3-spd Toyota T-case - with ~65:1 Low
Advanced Adapters - T-case/trans adapter and mount
New clutch - less than 150 miles
Willwood Slave cyl. - New Toyota Master cylinder - Kevlar braided clutch line
Prof. made custom woods drive-shafts
Custom front-sway bar
New Aussie Locker in rear (no trail use)
Billet hysteer arms - Rebuilt front axle
GM 1-ton Tie Rod Ends - DOM .5"wall Tie-Rod
Upgraded Forerunner Calipers with new pads/lines
New Forerunner 1" Master Cylinder
4-wheel disc brakes - Rear disc brakes with Summit prop. valve - all lines replaced
Bilstien 5150 remote res. shocks in front
New Monroe rear shocks
37" Goodyear MTR's - Front driver is new (>100m), the other three have good tread but have "rock rash"
Spare comes with vehicle purchase
Rear anti-wrap bar.
Interior / Exterior - 99% rust-free
Solid metal, no hidden rust holes
Painted sunrise red , random knicks n scratches
No hardtop / softtop - easy enough to obtain though
Custom Roll Cage & Front Hoop, all 1.75" OD - HREW steel
Brand new - Race trim seats - Fixed mounting
RJS - 5-point racing harnesses
Dash cluster has tachometer, vacuum, amperage, water temp., oil temp.
Upgraded Headlights - runs newer style brighter bulb
Floors - all floors have been replaced by with new non-stock sheet metal and RustBulleted, painted & Duraback'd -
Front bib/bezel has rust hiding in there, that is all - truck body/exterior is highly modified & is solid
I don't check here often so email me at funktyler@hotmail.com
or text me at 12043717127
Thanks, Tyler.
EDIT: I added a walk-around video!
1971_fj40 - YouTube
Here is a better for sale thread with more pictures
http://www.ct4wd.com/forum/showthre...il-rig-Built-FJ40-here-(roll-cage-37s-v8-ect)
Motivated Seller! TTT
Can an Admin please change the icon in the thread title from "Trade" to "For Sale"
? Thanks
I would love to take it off your hand but i though it was still in fl. Bump
It would be no problem to import this rig from Canada into the USA. The paperwork is very simple. Just fax the VIN down to the desired border crossing 72 hours in advance.
TTT
stock axles or are these built/inner shafts/birfs etc?
what kind of mpg on the tbi? what rpm this idle at?
rollcage tied into frame ?
Yes the roll cage is tied into the frame.
Stock axles, rear axle is welded and front axle is open. Haven't broken a birf or shaft yet.
TBI gets around 18mpg... Idles great around 800 rpm
Just needs a new home!
More pictures!
This is not a pavement princess or mall crawler... Built to be used!
Still for sale and a massive price drop. I'll take 5500 firm because the rig needs a good weekends worth of work now!
Needs one rear leaf spring replaced, one lower shock mount bracket, sway bar links up front, seat mounts to be re-done, some wiring work.
Rig still runs and drives, I start it weekly but its just sitting in my garage. This is a cheap price!
email me at funktyler@hotmail.com!
