For Sale 1970 Toyota FJ40 Land Cruiser
White Lake, MI
Year
1970
  1. 40 Series
Mileage
41199
Color
White
Outside Link
https://www.facebook.com/marketplace/item/524702236369252
1970 Toyota Land Cruiser FJ40 $6500. 42,000 miles on odometer. Clean title. Complete. Currently registered and legal and ready to go. All original parts. Previous Owner spray painted safari colors and used for hunting. Runs, drives, and stops great. Original Toyota straight 6, 3-speed column shift transmission. Has original manual steering and original manual brakes. Has all original Toyota badges. Interior in good shape, some corners have very small tears. Original Temp and Fuel gauges work. After market tachometer works. After market Oil Pressure and Ammeter work. Heat works. Speedometer does not work currently. Vehicle does have rust. There is a rust hole above each brake light in the body. There is a hole where the tire carrier used to be. The rockers could use replacing. Missing passenger side running board. The floor pans have holes that have been patched with license plates and could use replacing. The rear floor has been repaired in the seams. The rear window frame is bent in the middle. There is surface rust underneath the vehicle, but the frame is very solid. Windshield frame has been repaired several times by previous owner. Bottom of windshield is rusted out, could use replacing. Previous owner used spray foam around some edges of tub and around rocker panels. There are plenty of repairs that could be done to the body/tub of this vehicle, but I have been driving it as-is for the past year. Please message me with any questions at all. More pictures available upon request.
