1965 FJ45LV #2
Wired up an ignition switch and ran the motor alittle longer last night. It ran fine then suddenly died like I turned the switch off. Then it would not fire back up. I think the switch or the coil went bad. Gotta check tonite.
Sounds like points stuck.
Took off the Ramsey PTO and removed all the nasty, bubbling, and faded window tint. Looks alot better.
Some of those pieces are factory, you probably know that. Just thought I would mention. Fun project. I like some of those 4plus bumpers. You could do something like that .
1 out of 4 of those factory parts is still good. The rest suffered from hacking and bad welding. Personally I think those parts make the bumper stick out too far. I have an extra set that could go with this wagon though.
I got the frame all patched up.
That works! ;). Did you ever figure out the motor? Does it not stay running? Theories?
Never really figured out the motor. It kind of fires but won't run, I think it's got a timing issue. It needs to be TDCed and then check everything. I am done playing with it and have listed it for sale over on Ebay.
