just a guess but early 63, if you look at the VIN chart top of page, you see that they were producing about 10,000 a year in the early 60's.....if 22692 is Jan 1964...and yours in 20067.......thats about 10,000 apart.....just a guess though
this is the Data plate on my 1964 FJ45LV.......now its a very confused data plate as you can see(our motors are only 1K off, even 1-2 years latter) See the 45LV's were built by GIFU body.......Toyota sent the rolling chassis to them....my guess is they pulled them out kinda backwards(whatever was handy) when they added the body's, so mine is a 64 frame(with late 63-ish motor) and a 65 body(and even a 65 brass Tag).......and yeah all the # do match. 40's(and 45 trucks) are much more in sequence with each other.
Ours has a '65 brass tag as well, all very interesting. The oldest one I've had to date is a 10/75 FJ40, really cool learning about the older ones....a whole different animal.
I am thinking that it's late 63... Thus is only because of the ones that had been documented so far in comparison to the 64' that were also been documented ... There are flaws to the SOR chart in early years ... But... It's a very good resource regardless
Toyota's documentation of the early years has a lot to be desired
See here in the first post for 63' and 64' rigs as well as the total for the years at bottom
If you look at the engine casting number it might give us a better clue ... The number is on the drivers side of the block
For the life of me, I cannot find the VIN on the FJ40 anywhere. I've looked in all the locations outlined on this thread. I have a 1970 FJ40. It has been restored and the frame was powdercoated. Any suggestions are appreciated.
If it happens to have a shackle reversal, then the frame vin may be covered
Not sure if it will.work but instead of taking the powder coat off, maybe try some rubbing paper to see if you can read it. Assume the vin is on the title?
VIN is on the title, but the car came from out of state and has to be "inspected" before I can license it in Kansas. They can't find the VIN and I'm at a total loss.
It did have a shackle reverse.
Based on KY LongHunter's response - is that the exact location (midway vertical; just in front of tire before the bumper)?
Yep - that's pretty much it. My welded bracket/plate is slightly larger. When I went out to look at it closer, my fear is that the VIN was now covered up. You've all but confirmed that for me.
I would be contacting the seller about the two plaques a 70 model had when it was sold in the US. One on the passenger fender and the other on the driver's A pillar. You could go to all the work of removing the shackle reverse only to find the VIN is either not readable not doesn't match the title.
