12V distribution block- help
Tigard Oregon
I have been searching for a couple days now and can not find what I am looking for. I installed a Painless auxillary fuse box which has 2 key on and 1 constant hot leads fused at 20A a piece. I am wanting to put in 3 or 4 cigarette lighter receptacles in different locations off just one of the wires. I know about the quick connects that bite the wire and also soldering(which ive never done), but what I am looking for is a really clean installation. I have seen distribution blocks for large wire size, but I want one for 12-14 guage wire. What I want is a diistribution block with a spot to land the hot, and on the other side 3 to 4 spots to land wires gong out to the receptacles. I'd like to hear some experience from you guys with this, I cant be the only one that has needed this, I just dont know where else to look. Thanks mudders!
You could try google for terminal strips or terminal blocks. Look here for an example.
Bill
Thanks guys, looks like Blue Sea is where to go. Didnt want to spend $30 for something so small and simple. My searches were on "distribution block" and I guess thats not the right terminology.
thats more like what I am looking for, thanks.
Maybe you don't realize it yet but that is not what you asked for in your first post. The box on Slee's site is a fuse panel, not a distribution block. I was actually going to suggest when you first posted that you should run individually fused cables to your outlets. What you could do is return the 2/1 Painless fuse box and buy (or swap for) a 4/3 Painless panel. You would then have 3 constant hots for your 12V outlets and 4 switched outlets for whatever.
Not to hijack the thread but does anyone know which brand/model Slee uses in their set up. I am GUESSING its Wrangler but I have no way of knowing. And a part/model number would be very helpful. I realized last night that I really need to get my aux panel going and quick.
I have no idea what Christo uses. Here are the ones I use. They are made by Blue Sea #5026. The part number can be entered in the first link I posted. A list of various configurations should come up if you click on the link that comes up. Part numbers 5025-5034. HTH
Bill
I used a 5028 (6 pos) under the passenger seat and a 5025 (6 pos, 6 neg) in the rear passenger quarter panel. So far I've only hooked up a 12v outlet to each, but with 10 more spots to use I don't think I'll run out soon. Nice thing is they use the same fuses as the OEM fuse blocks, so it simplifies carrying spares.
He uses Wrangler, see page 59 of the Wrangle catalog.
Just spent a while trying to decipher the WranglerNW catalogue...limited information to say the least. Maybe if you're an expert in this stuff, which I'm not, it all makes sense.
Has anyone used their products Ior anything similar) to put together a fuse panel which is a combination switched and unswitched? If so, I would love to see some details. I anticipate needing 3 or 4 circuits of each flavor. I was leaning toward the painless 7 circuit (3/4 split) pre-wired fuse block but I would prefer something a bit more robust.
I also looked at the Blue Sea stuff and might go with 2 of their 6 circuit blocks but then would have to have a separate, non-integrated, relay for the switched block. The WranglerNW catalogue implies that you can integrate the relay into a block but it doesn't show any examples. I would prefer something integrated into one mountable block if possible.
Search doesn't turn up a lot of specific examples; just odd mentions here and there in the middle of threads on other subjects.
This info seems like it would be helpful to Azrider but, if not, then apologies for the hijack.
the painless aux. fuse block I have installed is exactly what I need, with 2 accessory and 1 constant. With each one fused at 20 A its plenty of room to run quite a few accessory outlets off each one. So with the size of the wire being 14 awg, I was looking for a clean way to distribute it multiple times. I dont think I need a entirely new fuse block for each lead, not to mention I cant find one that excepts such a small wire size as the input. I was planning on running a inline fuse to each outlet, but still need a good way to tap into just one 14 awg wire multiple times. Im still looking......
In the pictures are a couple of ways to do some multiple wiring. If you do not like the tight turns on the terminal strip wiring in the pictures they sell terminal jumpers. Scroll down on this Radio Shacklink to see some terminal strips and farther down a terminal jumper, Model: 274-650 Catalog #: 274-650. You can usually cut them shorter for a 4 position terminal strip from the same company. With a search you can find 4 position 20 amp terminal strips online for $1.29 if the Radio Shack ones are too expensive. You can also just make your own by drilling and tapping a piece of aluminum, brass, or copper strip. One in, 4 or infinity out.
That was why I bought the 3 fuse blocks in the previous picture. I was running almost all the things I added off the second battery. I made a list of auxiliary stuff that I wanted to come on with the key and was going to power one of these fuse blocks through a relay. The other was for the always on stuff and the third was for anything that I was forced to run off the main battery. It seems if you think you may need 4 circuits you end up with 12 in the future. Oh fwiw, those Blue Sea fuse blocks in the first picture are rated for 100 amp in and 30 amp circuits out.
Bill
Bill this just goes to show how much of an electrical novice I am. Never would have thought about crimping 2 or 3 together.
Corbet and Photoman- thats exactly what I need, Photoman's picture of the terminal strip I will find and use it at the entry point to the cab and then at each split off I will buy and use the 4-way splice Corbet found on ebay. Hell yeah, it will look good and now I can finish up this little project. Thanks alot guys!!!
NLXTACY
Lol, just don’t do it in your electrical panel at home.
Azrider
I hate to rain on your parade but personally I am not a fan of those 3 or 4 way splice connectors from the ebay link. In the past I have found they have a problem maintaining contact to all the legs. The center is just a crimp and you can usually rotate the legs about this ring crimp. This sort of loose crimp leads to corrosion and loss of contact. I used to even take a punch and smash the crimp but finally gave up on using them. Also, consider your amp load on such a 4 way. If you plug in 3 lighters (or heavy loads) on three of those 4 legs that loose crimp in the center is going to let the smoke out.
If you could even draw up a rough sketch of what you are trying to do, there are many very knowledgeable members here that could help you out. It would help if you knew or could estimate the amp load of your circuits and how many of them that would be on at the same time. I’m not sure but it seems like what you want has changed since the original post or very possibly I do not understand something.
Bill
found what I need at Pepboys. Just like the one in Photoman's picture, 4 in, 4 out. Will just jumper across one side after i land the hot leg and have 4 outs. I see what you are saying with the 4 way and it makes sense. Im not going to be running anything high amperage, pretty much convenience outlets. One outlet on each side between the 2nd and 3rd row seats (for fans for the kids- I live i Phoenix) and a duplex receptacle in the far back for things like my small air compressor. Plus a duplex on the passenger side of the console. I hope to post up some pics to share when im done, it will take me awhile, havent ever torn off moulding, side panels in a vehicle before, I hope its not too frustrating. Wish me luck and thanks for your help guys.
