100K Milestone!!
Orlando, FL & Southampton, NY
When I picked up my baby back in March of 07, she had this many miles :cool:
As of this afternoon, she has this many miles :eek:
She actually hit the 100k mark sometime early Thursday morning, but I missed it (original plan was to get video as she rolled 181,804.....oops)
To keep this out of chat, I figure I'd post up all major repairs I've made since I've had her :idea:
1) On the day I got her, both front signal bulbs blew out at the same time (weird)
Replaced them and they've been lighting up eversnce.
2) Piezo Buzzer for the alarm wasn't working.
Replaced with one I swiped from a Tundra and it's been chirping fine eversince.
3) Antenna mast got stripped out when my dad turned on the radio while parked under a tree.
Replaced the mast and it's been going up and down just fine eversince.
4) Got the dreaded PO401.
After some testing, it turned out to be the VSV and I replaced it.
5) Starter motor gave me random early morning delays for a week.
Replaced contacts and plunger and she's been cranking fine eversince. (also replaced the PHH with a Samco Silly hose while I was down there.....original PHH looked fine and came out in one piece)
6) nEverStart battery that came with the rig got weak after cranking up the new stereo system all day long in my shop.
Replaced it with an Optima Blue Top and she's been good to go eversince.
7) Noticed the carpet behind the 3rd row seats wear getting damp after heavy rainstorms.
Adjusted the lower hatch to close tighter and it's been dry eversince.
8) Noticed the PCV Valve grommet seeping oil.
Replaced both the PCV Valve and Grommet as well as the little "L" hose on the valve cover.
9) Right license plate bulb blew out.
Replaced it and it's been lighting up eversince.
10) While replacing the spark plugs and wire set (PM), I noticed a little oil around the #1 spark plug boot.
Replaced all 6 valve cover donuts and valve cover gasket. (also painted the valve cover while it was out)
11) "D" bulb went out one day.
Gave the dash a good slap and it lit up again and was good to go for about 3 months.
Then it finally crapped out for good and I don't have any plans to fix it as I like being able to dim all of the dashlights when watching a movies.
12) About 14 months after replacing the VSV, I got another PO401.
After some testing, it turns out the EGR Modulator had failed (bad diaphragm sucking in moisture).
Replaced it with an updated "Blue Top" Modulator and she's been code-free eversince.
13) During a routine belt tightening, I noticed the alternator idler pulley had seized.
Replaced it with a new one and it's been spinning fine eversince
14) Noticed an exhaust rattle coming from the passenger side.
Turned out to be a loose heatshield and a busted hanger after the cat.
Removed heat shield, welded the hanger back in place andshe's been rattle free eversince.
That's basically everything in a nutshell :) (not bad for a 13 y/o truck)
Anything else I've done has been normal PM without failure :cool:
Only minor quirk she has is the front windshield washer stops working on occasion :hhmm:
When I hit the button for the front washer, it spits out a little fluid, then shoots it out the back washer :confused:
This ONLY happens after hours of highway driving (otherwise, it works perfectly)
I've been told that it's the diverter valve in the washer pump assembly, but I don't have any plans on repairing/replacing it as it rarely ever happens :meh:
Anyhoo, I just thought I'd share :cool:
I'll update this thread in another 100,000 miles :grinpimp:
Sounds like you had a happy and relatively trouble-free 100; hopefully you can enjoy the next 100 in similar fashion.
If mine makes it another 100k miles, I will be astonished, since it is at 239k right now.
Wow, 100K miles in two years!
Don't mean to steal your thread. Since you mentioned oil around plug boot, just have a question - I replaced spark plugs for my Nissan Maxima, and noticed oil around #2 plug boot too. Is that necessarily the sign of valve leak?
It's probably just the donut seal in the valve cover, just like my #1 donut seal on mine.
The ironic thing is that you can drive 182K and still be considered a newbie by most of the members here!
WOW, very impressive. I hope to have the same luck, so far I still need 90k more :)
50K / year :eek: That's flat-out laying down the miles :steer:. Have you logged fuel expenses? I'd be curious to see your total.
You didn't mention axle rebuild. Hopefully you'll be doing that ASAP even if they were done just prior to taking ownership.
Lucky for me, gas is written off under our business ;)
As for the axles, I don't know if they were done before, but there's no mixing and everything is buttery smooth :)
I check the grease level on a bi-weekly basis and change the diff fluid about every 2-3 months...
I don't plan on pulling anything until I see the first sign of mixing :cool: (why try to fix what's not broken?)
Besides, if I ever go that deep into it, I'd rather replace them with new ones :meh:
182000??? you just broke it in! congratulations!!!:beer:
i wanna see ur fix, i always drive around wit it open
LOL
Actually, I do quite a bit of driving with the rear hatch open, but I lock the latch with a screw driver to keep the lights off :cool:
In fact, I'm actually working on a quick fix for this ;)
