- Joined
- Jan 31, 2015
- Threads
- 29
- Messages
- 715
I can contest ome is a tad stiff but I'm starting the weigh down the rig so it feels much better now nothing close to stock. But bare able
Im in the market to lift my LC. Im glad to see this conversation before i did. Why not replace the OME shocks with something more conventional like a lower cost Bilstein, Rancho, or Ironman? Is the Ironman shocks a bit less harsh?
Is there a different shock combo that works with the OME 2.5 medium lift kit that doesnt use OME shocks or forces me to buy $2,000 Fox, or Icon shocks? I dont plan on buying bumpers any time soon and ideally i would like to keep my ride smooth with a little added stiffness.
Is there such a thing?
The Icon stage ones are worth considering and not crazy expensive.... having had a GW as well I recall that ride....
cheers.
FWIW, when people speak about OME's they should list spring and shock numbers. Lots of shops use ARB's application guide and use the firmer OME shocks. Those are way stiff and we never use them, even on heavy trucks.
@sleeoffroad or anyone else...
I'm about to pull the trigger on a lift for my `99 LC but I'm concerned about all this talk about stiff rides with OME lift kit. What is the best solution if I want to run the 2.5" lift? Again, I don't plan on getting bumpers anytime soon and most of my use is 90-95% daily driver. I don't want my LC to drive like a tank, but I do want more ground clearance and slight performance upgrade when going off road.
I already have the SPC UCA on my truck. I was thinking about buying the Medium 2.5" OME lift in pieces (TB, 865 rear springs, differential drop down kit) and possibly getting more standardized shocks like Pro Comp, Rancho, Fox, etc... Does OME make a shock that isn't so hard? If I was to put on a 2.5" lift, what kind of extended/collapsed measurement in inches, should I be shooting for (i.e. extended 25.95" / collapsed 15.53")?
I asked this off Christo before but if I go with the 2.5" OME lift, will my LC ride stink bug? Which I don't want either.
