100 Series HVAC Controller - NAV DELETE - (OEM+)
Enthusiast Level vs. OEM Level
  • Enthusiast
    Votes: 21 21.0%
  • OEM
    Votes: 79 79.0%
  • Total voters
    100
  • Poll closed .
I really like this idea of an under the seat plate, but I have a different amp. Would you consider making them blank so the customer could make it work for them?
Absolutely can do a blank plate, or, I'll do ya one better - what amp do you have?
My plan is to integrate as many mounting patterns onto the plate as I can! That way folks can just use whatever holes work for their amp.
Awesome! It’s a JBL DSP4086
Do you think you could measure the mounting hole pattern on that one? (center-to-center distance & hole diameter). JBL doesn't publish that.
JL Audio 1000/1 & JL Audio 450/4, both V1 Slash amps.
Definitely not fitting those, hahah. I think they're slightly too tall, but, the length & width are definitely the killers. My plate has a (roughly) 12" square available on it (dictated by the surrounding seat)- according to the internet, those are both 19.7" long, and putting them side-by-side it'd be 18.5".
There'd be more length available if someone was OK with it protruding towards the rear seat some more, but you wouldn't be able to fit a setup of that width between the seat rails.
They are massive and need air flow. Putting them in the back.
The JBL amp is 9”x5.5”
Sorry - I mean the actual bolt hole pattern (i.e, space between the center of each of the holes in height/width, and diameter of the holes themselves).
For the LC folks - CAD for the HVAC module has begun! I had initially thought to keep the same size knobs & spacing as the OEM LC cassette deck had & the same size buttons as the LX470 HVAC module ended up with, but, I think it looks disproportionate. I think the buttons need shrunk, & the knobs need enlarged (giggle).
Thoughts? This is rocking the same 15° upward tilt on the display as the LX V3 has.
Awesome work!
You have my money. Now to be patient... Oof this is going to be an anxious wait!
