100 Series HVAC Controller - NAV DELETE - (OEM+)
Enthusiast Level vs. OEM Level
  • Enthusiast
    Votes: 21 21.0%
  • OEM
    Votes: 79 79.0%
  • Total voters
    100
  • Poll closed .
Anarchy
GOLD Star
USA/Canada
ALPINE SIEGE 100 SERIES HVAC CONTROLLER
Last updated: October 26, 2026
Web: alpinesiege.com
Instagram: @AlpineSiege
Facebook: Alpine Siege
THE PROJECT
Dedicated physical HVAC controls for factory-navigation-equipped 100 Series vehicles, allowing the factory navigation display to be removed and replaced with a modern double-DIN head unit.
The controller works with the factory HVAC system and retains the lower factory switch panel. Development priorities remain straightforward controls, clean fitment, reversible installation, and long-term reliability.
ORDERING AND PRICING
2003–2007 Lexus LX470 - Preorders open
  • $1,199 USD for the complete kit, paid at ordering.
  • Estimated delivery: Q1 2027.
  • Free U.S. shipping; selected international destinations available.
  • LX470 details and ordering.
2003–2007 Toyota Land Cruiser - Reservations open
  • $99 USD reservation, credited toward the $1,199 USD total.
  • The remaining $1,100 becomes due after the exact application is validated and the order is cleared to proceed.
  • Estimated delivery: Q2 2027.
  • Land Cruiser validation remains in progress. A reservation does not confirm compatibility.
  • Land Cruiser details and reservations.
Both applications require factory navigation. Delivery windows are estimates and depend on validation and production readiness. Orders can be cancelled before shipment for a full refund under the published terms.
DEVELOPMENT AND TESTING
Development began on my 2006 Lexus LX470, a U.S.-market vehicle built in June 2005. Testing has since expanded to independent owner vehicles, with more than 7,000 miles of development driving reported to date.
LX470: Vehicle compatibility is listed as validated across the 2003–2007 factory-navigation-equipped applications. Continued road testing, firmware refinement, and production preparation are ongoing. Compatibility validation is separate from completion of production testing.
Land Cruiser: Development and vehicle validation are proceeding separately. The LC version requires its own PCB and mechanical packaging. The revised PCB layout has been completed, with physical fit and assembly checks still pending.
Recent work includes faster temperature adjustment in firmware, revised display positioning, and further refinement of button fit and PCB support.
WHAT THE KIT INCLUDES
  • Standalone HVAC controller and display assembly.
  • Plug-and-play interface harness.
  • Mounting hardware.
  • Installation documentation.
COMMON QUESTIONS
Does this replace the factory HVAC system?
The factory HVAC ECU remains in use. The Alpine Siege controller provides the physical controls and display needed when removing the factory navigation interface.
Does the harness also handle aftermarket audio installation?
The supplied harness is for the HVAC controller. Your head unit requires its own audio wiring, mounting, and any applicable amplifier integration.
Are the buttons backlit?
No. The buttons are not backlit.
Is factory trip information retained?
No. The controller does not reproduce the factory trip-information screens.
Does it control rear A/C?
The controller operates the front HVAC system. It does not add rear A/C controls.
What finish is planned?
Matte silver is the default finish. It is not being represented as an exact match to the factory trim.
Removed during thread cleanup. See Post #1 for current project information.
This is pretty neat, nice work! Following along in hopes you develop something as I'd be interested in a module for 06 LX470 (prod date 06 2006). I'm sitting on a middle east non nav kit but lacking the board(s) needed for later LX470.
Would be great if you could list the toyota part numbers for the boards you're testing.
Thanks! and yep, 06/2006 is one of the initial targets.
I’m testing against the A/C Amplifier - part number family 88650-XXXXX.
Though I can’t say I understand the details, have a general idea of where you’re heading with this and love the effort. I would love to do an “easier” nav delete on my ‘03 LX.
Appreciate it. That’s exactly the motivation here, make NAV delete easy & allow the use of any head-unit preference. Still proving a few things, but if this holds, I’ll definitely circle back on earlier LXs like the ’03.
I could see it looking something like this.. one of the examples is a VW retrofit with haptic touch feedback.
I don't know what a lot of this means, but I have been planning to go the Teyes route and would much prefer this solution. I'll be eager to try this out on my 2005 LC when you have it fully figured out.
Thank yall for the support.
Just to be clear: this is not a quick-turn project & if you’re looking for a fast or inexpensive solution, this probably won’t be it.
If you want a clean, permanent NAV delete without sketchy screens or wiring hacks, this may be the solution.
More when there’s something worth posting
Still deep at the transport layer...
Bus is behaving more like a structured multiplex network so the focus lately has shifted from “finding commands” to validating packet structure, timing context, and acceptance conditions.
Isolated the frame families tied to blower transitions and confirmed repeatable OEM behavior. Current work is around why the HVAC ECU ignores injected sequences even when waveform and timing look correct.
No successful injection yet, but we’re past the guessing phase and into protocol validation.
This is proving to be a proper engineering project... 140 hours in.
Applaud you for diving into this. The head unit and HVAC controls are easily my least favorite thing about the 100 Series
Ok, I'll bite.... what exactly are you doing here? Are you creating a way to separate the HVAC controls away from the head unit? Would you create a separate HVAC contoller that would fit in the radio slot? I hope so.... I have spent literally hundreds of hours going round and round trying to figure out which option will work for me, and pretty much all of them sound like they aren't that dependable. I don't like the Tesla style because it is too big; I'm not a big fan of using the controller behind the head unit because you are stuck with the stock really low res screen; I've even considered the "portable carplay monitors" to sit on the dash, but again pretty much all of them are from not well-known foreign factories with lots of conflicting opinions of their value. This would be a godsend for me. If this is what you are doing, the heater controller would be separate, and then a person could go with a head unit from Alpine, Kenwood, or Pioneer? Is that what I am gathering here? One of the criteria I want to add to the unit is to have a aux video input because I bought an infrared monitor from Robofinity and I thought it would be cool to tap the video input from it to the stock screen. As usual, I am always looking for something that no one makes. I'll be watching this thread and waiting on purchasing something.
This is outstanding! As someone with a 05 LX I'm super excited that that's exactly what you're starting with, hah!
Let me know if you'd like some help with the faceplate design/integration. More than happy to contribute whatever I can to this project.
As someone who loves their 03’ LX, if I had an option to ditch the T’eyes for hard hvac controls I would do it in a heart beat.
Please don’t make hvac controls a touch screen! Please please please!!
You could almost name your price.
agreed. Anxiously awaiting positive results.
Following this Thread.
This sounds like a massive undertaking. We all appreciate the work you're doing!
I have a nav delete kit from overseas and haven't installed it yet- would that be compatible with what you're doing? Or would this be all custom controls?
