100 Series General Tech and Classifieds
While the parts guys at Toyota may not "recommend" changing the 6 heater hoses with the Ts, I'd still do it. On the three vehicles where I've changed these, two of them had hoses that were "less than optimal." If the Ts are old enough / bad enough to be an issue, (a) you also have to be concerned about losing parts of the crumbling Ts down into the heater system, (b) you gotta figure the hoses can't be great after that much time, and (c) since two of the heater hoses are connected directly to the heater core, it's better to cut those off rather than tugging them / twisting them and risk damaging your heater core (causing a leak.)
It's a little extra money (around $100 for 6 hoses and 2 Ts), but I think it's worth it........Just my $0.02
good info!
Finally found the best size and value cooler to go in the jerry can tray.
36 qt 46 can capacity
$30 Coleman Marine.
Lid has 4 cupholders to boot.
It been on the boat and back of truck most of the day and still has cold beer and waters.
My preference was this steel belted coleman 54 qt.
So damn close to fitting but just off a bit.
Someone in the 100 Series section found/used a metal fitting. Don't remember the specifics.
Grogan they look crusty. It's the part you can't see that fails.
Camron the fittings that some are using are PEX metal T's. The PEX T's are close in diameter but not exact. Personally I'm fine with spending and extra $16 at every timing belt for oem T's.
