100 Series General Tech and Classifieds
Funny. When you pull up that link, it says customers who viewed this item also viewed or bought these items. Nolen must have picked one up whilst shopping for red:
Lou check the tread Garth posted he is running a set of those wheels with same tire size.
i didnt find a member 'garth'...just garth66 and garthman...
not seeing any results from either similar...sorry. search is crazy.....
@dnp thoughts on newer GX460 size v 100. The issue I am facing is it we get another LC they only look "right" lifted w tires. GX and LX can roll bigger tires and good. Do you like your GX?
Sorry, JBo. Just saw your post.....
I really like the new GX. Very different "feel" than the former GX. MUCH tighter with springs all the way around (non-premium models have 4 springs vs rear air bags, and the former GX was always a little soft in the rear, in my opinion. On big bumps, it would routinely utilize the bump stops. Definitely was soft with the airbags, and once those were replaced with springs/Bilsteins, a little less so, but still too soft.) For whatever reason, the 4.6 doesn't feel as powerful as the 4.7 (probably due to a very different sound), but the rated numbers say otherwise. The 460 definitely handles better (iirc, all 460s come with KDSS). Overall, I like it as well or better than the 1st gen., and the fuel mileage is FAR better than 1st gen! If you can get the tires/wheels you want on there, you won't be disappointed with the vehicle.......
View attachment 1118399 This dude in Houston is putting out feelers on his Supercharged, 105K mile fully built 2002 100 Series. If any of you are seriously looking (and have the coin) you might want to hit him up before someone beats you to it...
He doesn't mention it in his build thread, but has replied to several WANTED ads in the classifieds and is getting the 200 itch.
https://forum.ih8mud.com/threads/the-start-of-rapidos-build.853800/page-7
G-Cat do you have the offset specs on those wheels? i am looking at getting rid of the MB wheels that are on my '06 LX470. they have a weird offset theyre 18x8.5 with 10 offset.
I do not. But the link to the build of that 100 Series inludes this:
They are 18x9 Et 12 BFD's by FN wheels w/ no spacers.... I'm ordering a set of 5 in gunmetal metaliic. I'd say for a 295 this is as aggressive as you can get... a 285 might be even a better option but I want as wide a footprint as I can get ..... I initially tried a 325/65/18 a while ago before i did the lift but that clearly was going to cost me some bodywork......
I tested the travel front and rear and this seems to clear.
RS6toFJ80 owns the 100 with the wheels. You could PM him. Good luck!
Gaaahhhhh, I got dem "FJ wheels". I'm diggin'em like I got a wedgie.
These tires are load range E so I can air them down to 35psi when offroading.
BTW, even though finessing this lift is a pain in a hunnerd der gree weather, it is pretty simple to do if you know "the rules of Hunnerds", meaning you know there's numbers to be conscious of instead of throwing it on the lift and yellin' ROH TAHDE!!!! ...like I did.
edit: pays no attention to the lack of a front center cap... the fronts have the stupid small spacers, which it needs to even bolt up. I've gotta git the 1" spacer set though. Just gotta order'em from the eBay's... tried locally and they were wrong from the fronts.
I like the stock 18" wheels. I think they look great. Simple. Easy to clean.
As for the 20's.......if I was considering aftermarket wheels. Which I would not, I would however consider 20's since I've already broken my OEM wheel rule.
I'm curious, would people consider the Rock Warrior wheels aftermarket?
Should I start a Pole/Poll/Pohl?
Meh, I don't care. They got a good beat and I can dance to them. I giv'em a 10.
what spacer are you running to convert the 6 lug 100 to the newer 5 lug tundra? I wouldn't mind having newer wheels on my 2006 seqouia
The Hunnerd isn't 6 lug. They 5 lug.
