100 Series General Tech and Classifieds
Last thing I did was add constant 12v in the rear for my ARB cooler.
The plug is all cheese so I need to replace it with something better. I need a double plug.
I ran a 10 gauge wire direct from the battery with an in-line fuse. View attachment 933256
Nothing wrong with that. A 15' - 20' run of 10 gauge is good for about 30 amps. The ARB fridge operates well within that at about 5.5 amps. As long as you fused it accordingly (hopefully as close to the battery as possible) you should be good to go.
Nice tech today, sir...wasn't sure you still had it in ya. :flipoff2:
I saw this sticker for the first time. It's under my steering wheel.
Is there a similar switch on your truck NTSaint? I didn't see a switch just the sticker
no, mine doesn't have that sticker, only one for AHC.
Still worried that my fuel issue is going to bite me one day when I can least afford for it to happen. Going to stick with the overheat theory for now I guess.
On another note found my first real-world good use for AHC yesterday. Needed to unhitch my trailer with the ranger and a bunch of gear on it, but since I'm going to go again next week didn't want to unload. Jack broke when I went to crank it up, and it's way to heavy to lift off. Put the AHC in High, ran some boards up under the jack, dropped the truck down to Low, and it lifted the trailer off. 5 years of ownership first time I've been glad to have AHC.
I got the VisionX light bar wired up today. I did a pretty clean job (for me)
I love this monster battery. I was able to make thus accessory post so i could keep from adding more to the other post that has the winch on it.
I added a fuse next to the battery for the rear plug. I left the other one in place that is behind the plug. Should not matter huh?
Post looks clean.
Let's see some pics of that light bar.
...via IH8MUD app
I used the Slee mounting plate for their light. It's not quite right since I used a different brand. Mine was ordered via Tolleson
for $300 v $700 for theirs.
Also the winch in my bar is too big for it to fit like designed so I had to use spacers.
It looks fine from 10' and it fills the area that is void on the Slee 100 bar.
Post some night shots of the light - light bar vs. headlights, etc. I'm curious how much light those put out.
Looks good, man. I want one of those light bars.
+1 I'd also like to see some pictures of how well it will light up a trail/road.
