100 Series Charcoal Canister Replacement
While filling up at the gas station, my 2000 cruiser has pretty intense fuel vapor smell. To the point that I move far away while fueling. It has never thrown codes, no smell while driving, and everything runs normal. Is this charcoal canister related?
98-02
charcoal canister = vapor canister
Constantly getting the CEL for 0440. Did the gas cap, checked lines, now onto the vapor canister. Do you know which one is the correct one for an '02? Is there an appreciable difference between these, other than $100?
Why not buy it from Toyota dealer for $404, which is $143 less than the lowest price from your list?
This is the exact issue I have in my 2005. Strong fuel vapor smell during refueling, but no codes or driveability changes. Did you ever find any resolution?
The previous owner of mine states that charcoal canister was replaced at some point although did not have paperwork to back it up. From the looks of the canister compared to other under-vehicle components, it does look newer. Probably kept original hoses though. Thanks
I replaced my entire charcoal canister and valve etc from a 2007 Scion TC at the junkyard. The Scion can was about 1/2" shorter otherwise identical. My can started leaking where I epoxied it together. I still have the external vent blocked off, get a CEL every so often that I just clear for failed purge valve test. My truck doesn't smell like fuel anymore and my fuel tank stays sealed.
Please explain the external vent block off
I have a charcoal canister recently replaced if anyone is looking. Came off the version that attaches to the rear of the vehicle. Made small holes to empty the old charcoal. Came off a 2003.
