#1 Speed Sensor Tests OK - Pics
Lift a tyre, open the ignition, do not start engine, have a friend move the tyre, have a tester...3 wires, 2 are positive, one negative, locate the two pos, by elimination the left over is the neg...the friend moving the tyre is for one of the pos to work...I know, kinda rudimentary, but it will be a diy kinda thing
Great idea... thanks man.
Check the ground wire that attaches to the rear of the intake. This is the ground for your speedo. Chances are you may have loosened it while doing your PM or it just has a bad connection.
Can anyone point me to where exactly this is? I can't find the ground wire.
Having the same issue as of last week :(
Dead speedo/odometer
When it originally started acting up, the needle would bounce all over, then it finally gave out.
I pulled the VSS (easy one), cleaned it up and re-installed, but no luck.
Didn't pull the actual speedo gear or wiring tests, but I did check the ground and it's solid.
So that pin is not supposed to come apart from the VSS. Guessing you had the same problem I just resolved, you had a square pin in a rounded off hole... That's why you were not getting a speed or odometer reading.... In my situation the PO put in a cheap knockoff part and it didn't last. Get the Denso part and you'll be good.
