I have a Lexus lx450 with a swapped 1hdt with a single battery set up.
Had the stock oem alternator replaced a few years back with another oem, ran fine for a few years and just started seeing low voltage again (in the range of 12.1-13.2 on idle and throttle).
Had the alternator swapped again and truck was running fine, voltage at 14.1 on throttle for a few weeks but have again started seeing a drop in voltage in the past two days, back down to 12.3 at idle.
Ive peeked around the sub on the topic, outside of cleaning grounds, possible regulator issues, any other suggestions or possible culprits I should look out for?
