'08 - Driveshaft Clunk/Thump....
Gilbert, AZ.
My VIN falls within the affected range as noted in this TSB. Local dealer quoted ~$375 with tax, part is in strock.
My "clunk" ONLY happens when accelerating from a dead stop (it happens every time). I don't hear it EVER "just before or after coming to a stop" (quoted from TSB). Since my experience is slightly different than how others and the TSB itself describe this issue:
  1. Is it possible this isn't the same clunk? Would hate to drop $$ if this isn't going to solve my particular issue.
  2. Anyone know of a less expensive resource to buy OEM parts? I've seen other posts where folks have spent noticeably less on the same part.
Thx everyone - Happy Holidays!
Test....
that is it... i had the shaft replaced and it is worth it.
the less expensive option... keep greasing up the shaft every month or so... but the TSB is the fix.
From previous posts this is what I wrote down....old defective propeller shaft assembly #37110-6A480...new upgraded part #37110-60A40
Crazy they went backward with the new part #. Thanks for the info Lexus parts has it for a little over 200 bucks. So better get it now
Here's the actual TSB that I saved from another post
Thx guys - will order now.
Which site are you referring to? I found lexuspartsnow.com but it's over $300 with shipping.
Correct per the TSB (thx for attaching it as well).
Aside from the clunk, do the defective shafts have any propensity to fail? I may just live with the clunk for a while.
