Iron Pig Off Road– Some Functional Products
I just clicked on the ad here for Iron Pig Off Road (IPOR). I never knew of them. Despite the slightly misleading name, they have some great products for FJ40s, too. (I'll leave the FJ55/60/80 stuff to posters in their respective forums.:D)
Some FJ40 stuff that peaked my interest:
FJ40 Rear Bumper:
Frame huggin design with stout tire carrier. I wonder if the ends bolt to the rear crossmember outboard tab captive nuts. Looks like a strong swivel support, too. I really like the repositioning of the oem tail light lenses, but they probably need more protection down low. I'd order one uncoated and add a ice chest tray to the swivel arm and lense protection. Good price compared to MAF offerings.
Customfab
Nice "Southco" compression latch. That has fab potential.
Are those oil impregnated bronze bushings for the door hinges? If so, then we wouldn't have to use the plastic door hinge bushings SOR and MAF offers.
The bumpstop has promise, too.
At the bottom, they show a tire carrier mount that would let a DIYer only have to make the bumper and swing arm without the hassle of the tire mount. Only $89!
I wonder if IPOR also sells their swivel point innards separately. Is that what that sping pin is? Or spindle assy? Screwed up pic, that last one. That would reduce home fabbing a custom bumper to just the bumper and the arm with welding. I think even I could do that.:grinpimp:
Skidplates:
The FJ40 skidplate has a smoother design than stock. Also made of 5/16" steel. I'm still using doubled up oem skidplates welded together and they do bend some, though less since I reinforced them. Still, IPOR's version is much smoother and stronger than even two factory plates.
I like the flat belly that's flush with the frame except for the xfer case pocket. A little expensive for a simple item, but I wouldn't do much different since I'll keep my 4-speed xfer case in stock position hanging below the frame.
Seats:
Isn't $185 for that rear fold & tumble seat a good price? If one wanted to go with the front Procar seats, the rear tumble seat would match. I wonder if the rear seat's front bracket holes line up with the captive bolts in the floor rearward of the front seats like one of the Mitsu Trooper seats do. Or would drilling be required all around?
My '77 FJ40 has the oem seats that don't have reclining seat backs, so I'm looking for more comfortable and reclining replacements. I also wan't to replace the rear jump seats with a fold and tumble seat, so I'm definitely keeping IPOR in mind since getting front seats and a rear fold & tumble seat to match would look great. I never knew matching aftermarket front & rear seats from the same mfr were available for an FJ40. Learn something new everyday. :cool:
Dang, that is a good price on the rear seat. They give the dimensions for the front seat but not the back. Does anybody have the width? I'll have to email them and get more info. That would look great to have all seats match perfectly without resorting to seat covers.
4x4Poet said:
Customfab
Are those oil impregnated bronze bushings for the door hinges? If so, then we wouldn't have to use the plastic door hinge bushings SOR and MAF offers.. :cool:
Those bushings are for the spindle assembly not for the doors.
The seats are Steel Horse which is now Procomp or 4wheelparts.com.
I have the front buckets and the fold and tumble.
The buckets fit a 40 very nice and all you have to do to mount them to stock sliders is cut 4 pieces of 2.5" flat stock and drill some holes. The rear fold and tumble is a perfect fit and just snugly fits between the wheel wells.
ALF
So, 4x4Poet; what part of IPOR do you find even slightlly misleading? And, how long have you been living under that rock? Lance is already pretty famous.
<edit:> And isn't this chat?
I stopped by their shop a couple of weeks ago... They were nice... Busy but nice. Lance the owner is doing his own truck... He took time to show me that; and some of the things that he did were innovative. They obviously have a very some good craftsmen there because the work I saw was top notch.
Thanks. I didn't pick that up from the site, but it seems obvious now since the bushings are listed along with the spindles. Doh!
The buckets fit a 40 very nice and all you have to do to mount them to stock sliders is cut 4 pieces of 2.5" flat stock and drill some holes. The rear fold and tumble is a perfect fit and just snugly fits between the wheel wells....
First hand info. Excellent!
The interior page claims the seats are Procar, not SteelHorse or Procomp/4WP. Do you know something different or was Procar sold/renamed? IPOR interior link:
http://www.ironpigoffroad.com/interior.htm
I also reviewed that page again and noticed that the site doesn't pointedly say that the seats fit FJ40s. Just Land Cruisers in general. No mention of plate fabbing and drilling. Direct bolt in for FJ60s. Do FJ60 seat frames differ from FJ40 seat frames?
Nice to know that the fold and tumble seat fits between FJ40 wheel wells, er.., well. Could you describe how they are mounted? I'm particularly interested in whether all mounting holes had to be drilled or were some captive nuts in the FJ40 floor utilized. What seat belt accomodations do the seats have, if any.
Thanks for the heads up. :cool:
Pighead said:
So, 4x4Poet; what part of IPOR do you find even slightlly misleading? And, how long have you been living under that rock? Lance is already pretty famous...
I consider only FJ55s "Iron Pigs," but IPOR offers parts for other FJs. Call me a purist. :D
Maybe. I thought I had tech questions, but the mods can move this thread as they please. No objection here. :)
Just tried the links, looking for bumpstop options. All dead.:frown:
Mark,
Recently (2-3 months ago) Iron Pig changed their website, they moved a lot of things around to make it easier to navigate. You can still get to the root of the site, by going to www.ironpigoffroad.com, I find that it is easier to just call them 1-866-IRON-PIG. Any particular bumpstops styles you are looking for?
Ryan.
Mark,
Ryan.
Thanks Ryan. I did try the root site, after doing a LOT of thread searching here. Couldn't find the bumpstops mentioned in the original post anywhere on the site. Looking for something to fill in approximately 10" of my 13 inch gap on the back of my 45.
Best
Mark A.
Mark,
I think that the mention of bump stops in the original post was actually for stopping the swing out arm on a swing out tire carrier. I have looked around for bump stops and I found a fairly affordable bump stop from Poly Performance. It is only 4.5" so you would need a drop bracket and probably a raiser on the axle. I will keep an eye out for something longer.
Ryan.
Does that rear seat they sell face forward or backward?
