Best year for a 40?
Golden, CO
I'm on the hunt for a 40 and have heard varioius opinions on which year is best. I would like to go post 76 for the disks but chime in and let me know what you guys think is the best year considering parts, set-up and what-not. Thanks. I've heard 78 is the best year ???
:cheers:
I have heard numerous times that a 78 is the best year mechanicnally. It had the 2f, 4:11s, and i can't remeber all the options. 79 and up are nice, except for the 3:73 gears, plus you can usually find one with power steering, and maybe even ac.
Rod
Thanks. I heard 79 and up it gets harder to find replacement parts, has that been anyones experience?
I'd try to find the best '76+ you can afford - the metal is better on the '76-'78, but the '79+ can be had w/ factory AC and PS. The later ones also have a better ignition system and larger fuel tanks....and better highway gears (depending on what you plan on doing w/ it). I'd buy a '79-'83 if I was starting over...just my .02
Good luck!
Tucker
OK so what if there is a pre 76 that has a disc conversion and PS? What year did toyota switch to the 4 speed trans?
Dont know how tall you are but, I am 6'7" and have much
more leg roon in a 79+ rig, as the gas tank was relocated
and the seats were mounted diff. You may already know
this. Just my .02
I think 1974 was the first year for the 4 speed.
oh yeah 74 is pre smog in most states too.
JimK
74 has the 4-speed, 73 has the 3-speed, 76+ is disc, 78+ is fine spline pinions, 79+ is 3.73 gears and goofy tub (I'm not a fan), 72-73 have the good lower t-case, 79+ has the bigger minitruck birfs and knuckles
if you want a daily driver, or casual offroader, the 78 is the best starter...discs, fine spline 4.11's in later months, and the easier-to-adjust tub with the underseat fuel tank.
if you want something to build, then lean to a 72-73....stronger of the early t-cases, an easy swap to a 420 or 465, F motor works well at crawl speeds, minitruck disc conversion is also cheap.
just to throw a wrench into the works... :D
depending on where you are, a pre 77 (ish) would be pre-emmissions and therefore not have to be tested/inspected. This *could* be a good factor as you can do whatever you want to the engine, and it didn't have cats to begin with (non-CA anyway) so you don't need them.
the brakes/tranny/diffs you could build up yourself
just a thought....
I have a '79 that I like a lot for the reasons mentioned above. What about the quality or thickness of steel? Aren't their different gauges of steel in the different years? Just throwing it out there.
You are in California so smog is a huge issue. There has been a 30 year rolling exemption from smog testing so a '74 would be exempt. A 2F motor has enough going for it that I would go at least '75 to get that. You can always convert the axles to disc parts-it's easy. 76-78 are all very similar. The '78 does have a fine spline pinion, but you'll probably swap gears anyway so that isn't a big issue. THe draw back to the 76-78 is the "non-standard" birfield. They are different from all the later birfs used in minitrucks, later 40's and all 60-62's.
My best advice would be to get the best body you can, and make sure the frame is not rusted. You will have to spend lots of cash to get trail ready anyway. The best FJ40 is usually the one you have, so buy one, be happy, and modify it the way you want.
I'll chime in and agree that the 76-78 are the best years. Of course, thats beacause I have a 77.
Good Hunting!
also, best sheet metal on e-72
75 isn't even to bad, same as a 76 except for the disc and the rear tire carrier.
76-77, nice, 2f, 4.10's, disc
78, same but fine spline 4.10's.(this year is fairly sought after)
79-80, 2f, square bezel, same birfields as mini or fj60, OEM PS bolts up, 3.73's, cats started in 79 I recall. Tank underseat?(I forget)
81-2 is a fj60 is a fj40 body, 2f(same as a 60, carb is the same, everything the same) split t-case, e brake on rear axle, 3.73's, 1 mil on the speedo. MUCH more room in front seats, gas tank under body and is a PITA to replace. there is NO issues with parts, no spendier or harder to get than others, maybe even easier. I think 80/1 the springs changed, same size bushings that fj60's used. also steering wheel is different 81+, 8/81 got a gear deduction starter. Basicly when the fj60 came out the all the fj40 mech stuff changed to what a 60 had.
83 fj40, same as a 81-2 but with a seperate dash
79+ sheetmetal seems to have more rust issues.
I s*** you not! both my 82 fj40's are the nicest driving 40's, it shocks folks that have never driven one......they are a dream to drive and even my green 82 with 3.73 and 33's has TONS of power, no need to drop to 3rd on any hills. Gets good milage. a buddy with a 77 set up just like my 82, took my 82 out for a drive, he came back shocked at how much different they are.
I have said it before, but if I only had to keep one cruiser it would be the green 82 fj40.
But like someone else said, find the best body you can, the mechical stuff can be replaced easier than the rot.
so IMHOP........81-2 are the best years for a daily driver and casual wheeler. Also 81+ will hold the best re-sale........but will also cost more for you to buy now. You don't have to spend alot on one........there still are some good deals......my 82fj40 cost me $5500, I have another 5-6K into it, I wouldn't sell it for 30k.
oh.....AC and PS were ALWAYS an option, never standard.
hubs, ALL fj40 came with driveplates(fixed hubs) anything but this was dealer or PO installed. Asco and Aisin were a dealer option in 79+ I think.
Are you looking to go completely stock toyota everything?
IMHO, having owned a few 79 fj40 and having both 79 and 75 now, I would
never own anything pre 79 if i can help it.
Body is just so much different, huge amounts of room under the tub, to get to things you might need to work on, or for any conversion or custom drivetrain. Factory PS is not that bad stock on a stocker. I HATE the goofy center cover on the earlier fj40s.
not totally sure about different sheetmetal on the 79 laters, but i been thinking that the paint makeup is different, seems like the paint/primer is just not standing up as well as the earlier. Maybe some chemical caused cancer and they stopped using it? i dont know, LOL.
All this and i am looking for another 79 or later, parts vehicle or builder, i need a starting point for a wheeler!
long live the SQUARE BEZEL!!
I love my 79. Have driven an 82 quite a bit and owned a 76 previously. 76 was great, drove more like a tractor than my 79 does and more so than the 82. The 82 was a bit more roomy, and had extras like defrosters for the side windows and the rear heater built into the center console. I personally prefer later than 76. I searched for a year before finding mine and I've done some nice improvements, so I really don't want to sell it. It did come with the A/C option which I need to get working again, PS was not installed. Not worth any of the extras to start over looking. Although, I might consider trading you for your 55 :-). Nah, I;d rather keep my 40.
Just do your best to find a decent cruiser at a good price. You'll love whatever it is you get.
I really like the inside of the 79+, they seem to have more room, and with no tank under the seat, and the shorter tranny hump. Is there really a bad year of cruiser? I have had a 78 40, and now have a 70 40, and have a 93 fzj80. was the 4 speed better, yeah, but it isn't quite as cool as the 3 on the tree. The V-8 I had was awesome, but the inline 6 is pretty cool also, love the way that 6cylinder sounds.
