[quote author=robbie link=board=2;threadid=15124;start=msg142820#msg142820 date=1082560986]
I do hope that you have a few dollars for the fender flares set aside. I just can not believe that you have no rub. We put a set of 37/12.5/17 on a crusier that has 2 inch body lift, J spring in front and 863 regular in the rear to set level. He has lot of rubbing currently and has to do some triming to the flares and some mods to the front bumper. Lots of trim removal in the rear. Nothing else these tire have to rub on the rear fender wheel well and frame. My 35 trxus rub in this area with my modest 4 inches of lift with a stock 80 series wheel. The back spacing on the wheel you have chosen is deeper than a crusier. I would also think these rub on the front control arm at full wheel lock unless you adjusted the knuckle stops.
If you choose to put 1.5 spacers on your truck There is not doubt in my mind that you will contact your fender flares and the inner fender in the rear. As for the front I can see the tire contacting on turning the front fender flare. I know that is also a problem for this truck we just put 37's on.
The pictures are nice light wheeling almost a cruse to the mall, come play in the mountains with that set up and see how you fare on the body damage.
I currently can not fit any thing bigger than a 35's on my truck with out rub, I know I have a set of 13/36/16 Swampers I tried to put on my truck this moring and they will not fit with out either putign in a 5 inch bump stop spacer, or going higher on my lift. Or the other way is to trim the body so they will fit under full compressionI am planing on my next move so I can wheel with these with minumial rub.
Have you tried self clearencing, go jump a sand dune or a good whope de doo and see what falls off.
Of course this is all my limited experence with building crusiers and the limited years of wheeling and is only MHO. later robbie
[/quote]
I just installed the meats last nite so haven't had any real world wheeling measurements/rubbing yet...I went out and ran around the parking lot just now and at FULL LOCK i get maybe less than 1/8" rub on the lower control arm (this is when you can hear the power steering system making it's noise full lock). I couldn't even hear it rubbing, just could see very small rub marks. Still not done trying too make them fit perfectly though. Of course, wheeling and having the tires take off what they need to is fine by me...that's how I'm currently removing my rear bumper (a la rock)
I should note, that the wheels are 7.5" wide, they have 4.75 (i may have said 4.5, i was wrong) back spacing (stock is 4.5) and that I will plan on running 1.25" spacers (1.5 is too wide). Now here's something that may make more sense to all of you: The tread pattern mounted ON the rig measures 10.25 wide and then bulges outwards (thus clearing what it needs to clear). Here's something our rigs do to the tires due to the weight (and maybe a bunch of other factors...7.5" width tires, etc.)....they measure exactly 36" at 30psi. I measured my spare @30 psi...it measured exactly 37". So we get 1" of squat once mounted. Also, I normally wheel with a lighter load compared to some of the full on setups and drawers and such. Granted I will have a few spare parts weighing down the rear of the rig soon :d, but I plan on accomodating with spacers.
I run 2" bump stops in the back and will be putting 1" on the front. I had the trxus tires and they only rubbed on the rear frame at full flex...in the mountains of CO (btw, will be there first week in august with LSLC/GCC/TAC)
Nothing a frame couldn't handle. The fender well didn't rub due to my 2" bump stops. Also, I have yet to wheel super hard core like some of you guys, but I live in the flatlands of KS
ONE day I will make it to CO. and break stuff like a real man!!!
really, it comes down to the combination I chose (7.5" rims, 1" more squat on the tire once mounted, some magic dust, etc.) Most of you guys run 9 and 10" rims when running >36 right? maybe that causes the tire to have a wider stance, thus the rubbing...Just some thoughts. Plus swampers are just plain bigger than stated sizes.
Bob Garrett took a ride in the rig last nite and can attest to the fitment. And please do keep in mind I do plan on doing other mods to help my flex, reduce my body damage, and keep the rig stable. I"m not going into this totally blindly (ok, maybe one eye)
Regarding the swampers you tried to put on...they are 13" (.5 inch wider than what I'm runninng, and probably more than that since swampers run on the large side...except the trxus). Not sure the taper onthe tread pattern either, as with the TSL setup, the lugs do stick out quite a bit, krawlers don't. Now aired down, things may be better, may be worse. Tire will get wider, but will get shorter too.
If anything I said came off as offending, I applogize in advance, I'm in a rush to get to work (I work nites, and have day meetings...yeah, like you wanted to know that)
K
