The love-affair with my new 80 is OVER.
Fort Apache: Victoria
For the following reasons:
1) for the CEL coming on literally a half-hour after I paid for it, signalling the end of the brief period in my ownership when it worked perfectly. A period which shall never return, apparently.
2) for that CEL to read a Code 71. Cleaning the temp sensor fixed it for a day, and now it's back (code 71).
3) Because after spending $1900 on a complete front end rebuild, including Longfields, the front end still binds. the rear end might be binding when I'm backing-up whilte rurning. I'm not sure, because of the noise the PS pump maks (see #4). Why? Damned if I know. Clearly there's something fxxxed in the transfer case and/or the CDL. The reason is academic, anyway, because I can't afford to pour any more money into this thing. If I wanted a 4x4 money-pit I would have purchased a Disco; at least then I'd have a heated ass.
4) Because the whining, stiff power steering pump was replaced today at great trauma, and the pump that replaced it is slightly less whiney (only sounds like ten seals being strangled instead of twenty), and is more stiff and unmanageable.
5) Because the speedometer was fxxxed and now isn't (but for how long? You tell me!).
6) Because I have had food poisining for two days, and although there's no pysical evidence, I bet it can be traced back to my truck, somehow.
I've been a Toyota guy all my life, and I'll buy another one one day, but my 80 is a lemon and I'm going back to 4Runners.
BC guys, if you have a third-gen 4Runner with rear locker you'd like to trade, let me know. You'll get such a bargain.
So you bought this sight-unseen off of ebay? Bummer that you were blind-sided by a piece of crap.
Seriously, sorry you ended up with a lemon, but don't let one bad truck ruin the 80 series trucks completely. I had a bad sandwich once, but I haven't sworn off of sandwiches as a result.
Take a little time to settle down and figure out what is wrong with the front end binding. Might be something simple that was overlooked. I hear you on the PS noise, as mine is starting to get loud again (leaking a little), but it sounds like you have a couple serious, but fixable issues to take care of before you decide that the 80s aren't for you. Lots of help here to figure these out, and if you can wrench on it yourself, you might be closer to the 80 you wanted than you think.
Good luck, man.
1. Read RT's threads on egr
3. What is binding in the front end?? I haven't seen any questions from you on the board about binding....
4. have you tried searching......downey and a fluch usually does the trick...
5. cuz you pressure washed the engine.......
You have minor problems, this is a 14 year old vehicle, it needs some love. And none of these things will leave your happy hindparts out in the woods like a disco would
Stick with it and you will thank yourself later.
Dan
ps. you shoulda bought mine:D :doh:
Dood, I'm sorry man. Truly! It happens to the best of us. It's always a crap shoot buying a used vehicle.
I hate hearing stuff like this. It's kinda like when you see another guy take a hit to the nads. The whole team winces in sympathy...and then covers their own package!:eek:
Wish I could offer more than just sympathy.:frown:
I hope you don't leave, cuz I've enjoyed your contributions to this board.
And I like your avatar!:)
1/2: CEL's are tough to get rid of. I don't worry about them too much.
3: Longfields are overkill unless you are going to be doing serious rocks, serious angles, and run 40" tires. There--you could have gotten $700 back in your pocket. Did you pay someone to do the front end job for you or did you do it yourself?
4: The only way to get rid of a whiny PS pump is to either rebuild it yourself or get a new OEM unit. Downey and all of that stuff is just a stop-gap measure.
5: Not sure here.
6: I doubt it was the cruiser but I hope you feel better.
No one ever said that you just get a cruiser and everything is kosher. Don't underestimate the cruiser. It will come back to haunt you. ;)
Good luck.
-onur
take a deep breath and a few :beer: , park it for a while, and deal with the issues one at a time with advice from here later on. No biggie. Soon solved and you're good for another 5 years... :)
Ironyuppy,
So sorry to hear of your trouble. I know it's a real bummer when you've dropped coin, and still have issues with your rig. I was bummed out for a bit about mine, but after a while got over it, and went back to work on it.
I hope you can, too.
BTW, I didn't swear off sandwiches when I got a bad one, but it was a good while till the next one.
HTH,
DTaylor
1&2 -- EGR codes will happen to every EGR equipped 80 series sooner or later. There's nothing special about yours other than it appears the PO was shaddy enough to reset the computer so the light would stay off just long enough.
3 -- You'd have to describe "binds" more. Is there noise that accompanies it or just the feeling that the front tires are gripping dry pavement when you turn? Have you tried determining if the CDL is engaged?
4 -- Did you replace the pump with OEM or aftermarket? What condition is the steering stabilizer in? When my oem stabilizer went bad and lost its fluid I had similar symptoms. I've also read of at least on member reporting the OME stabilizer causing their PS pump to make noise.
5 -- You'd have to further define "fxxxed."
6 -- Stay clear of cheap all-you-can-eat Chinese buffets.
btw - how many miles on it?
Sorry to hear of your frustrations.
Still can't find a better used truck than the LandCruiser! You probably haven't beat the s*** out of it enough!!!
Take your time, fix it, and drive it.
If you had read the threads here you would have found no one has ever fixed the EGR by cleaning the temp sensor,
If all you are going to do is complain you are not going to get far with your "lemon". If you put forth a bit of effort towards figuring out your problems you might make some progress.
Is it too late to get the sugar coated reply:D ?
Hmm.. I had Code 71, took out my EGR temp sensor per this thread and cleaned it up... No more Code 71. IronYuppy's doesn't appear to be that easy to fix, maybe carbon in other places that needs to be cleaned out as well?
Sorry for all your troubles, yuppy, I understand the frustration of time/$$$ and no results...
Ok maybe somebody has, :doh:
Anyway, giving up after just cleaning the temp sensor seams weak to me.
Can't understand the $1900 for the front axle. Could have done it yourself for $200 and there was no reason to go to longfields.
Does sound like the PO cleared the codes before you bought it
The power steering pump sound could be from something other than the power steering pump.
Did you have this truck checked out before you bought it? Everytruck takes some baselining after you buy it. Sounds like your was purchased from a poor PO. Once you work through these, you should have a great truck.
On your binding issue, lock your CDL switch (If you have one) and remove the front drive shaft. Your binding issue could be U Joints, but hard to tell without more info. Please describe the binding sound and we will help. If you don't have a CDL, let us know and we will tell you how to have it engaged in 4 HI.
I own two 4runners and 2 80's. The 4runner is a great truck. The 80 is an awesome truck.
So if you bought this truck without having it checked out, then you made a mistake as any truck can be run down by poor maintenance. You can learn from that mistake and we can help you fix this truck, or you can just as quickly get rid of it as you jumped into it.
I wish you luck in whatever you do.
Seems to me you're throwing money into repairs that you haven't thought through. Slow down and take it easy. First thing is to find the binding problem. No need to jump to conclusions that any major part is gone as that is not likely the case.
The CEL code is two trip logic so it will take two drive cycles for it to appear once cleared. So don't view a reoccurring CEL as ANOTHER problem, you just haven't fixed it yet.
The PO obviously hid some issues from you and that's part of the online game. I bought a 96 Camry that drove fine! When I picked it up the shifter would lock in first gear if you were not really careful. Just fixed it and moved forward.
We're all here to help you out and will do so readily. No offense, but you really are in no position to make repair decisions on your own, you should allow us to help guide you until you have a good understanding of how these things are built.
If you were anywhere near me, I'd make you an offer. Do you deliver? :D
Sounds like relatively minor issues masquerading as big problems. If you don't want to deal with it, sell it to someone and stay away from older cars.
-Spike
Amen... We should all meet up at your place....
