The grease trick didn't work for me. Some people say bread is better.
It'll take you three hamburger buns
Dan
3 buns?? I'm lost. I'm looking at the 1-1/4 inch diameter bearing in the end of the crank that supports the input shaft of the transmission...
you must eat really small hamburgers?? : )
so you guys are saying push the bolt or dowel in and the pressure builds up on the bread and pushes out the bearing.
Used the bread idea, only used the top half of a sesame seed kaiser...5 minutes, and popped out, cleaned it up too : )
okay, fine, i will give it a try but the proper 3 jaw is clean, easy and the bearing is on the ground in seconds (of course i have come across a couple that refused to budge. THOSE i would like to see removed by bread or grease method...
Nice to see this idea! Separates the wheat from the chaff, got a rise out of a few people, and leavened the situation. I'll have to try this next time, even if it sounds somewhat crumby. Sorry, but I figured some humor was the yeast I could do.
gb
