- Joined
- Oct 4, 2008
- Threads
- 193
- Messages
- 6,158
I figured I'd post up a new thread since several members are planning on adding a FJ80 washer bottles by using Landtanks charcoal canister relocation bracket.
See these threads for additional info;
[URL="https://forum.ih8mud.com/80-series-tech/494618-pic-request-left-side-engine-bay-early-80s-3fes-washer-bottle-efi-relay-area.html"]https://forum.ih8mud.com/80-series-tech/494618-pic-request-left-side-engine-bay-early-80s-3fes-washer-bottle-efi-relay-area.html[/URL]
https://forum.ih8mud.com/80-series-tech/257860-another-washer-bottle-solution.html
I just happened to have a JDM washer bottle collecting dust in the garage for several years (thanks Giraffe). It's pretty much the same as US bottle but with one more hole for the washer pump. The install for US bottles will be the same minus running the ducting and mounting the head light washer nozzles & associated wiring.
There are several steps here. I'd start with removing the battery and tray followed by the charcoal canister & fuse box bracket. That way you have plenty of room to work. Also remove the corner light so you can slide the back washer bottle in.
I happened to retro fit an extra relay and fuse into the empty locations of the stock fuse box when wiring up the CDS Fan so that part was already done and will not be duplicated here. Here are several links to that for those interested.
https://forum.ih8mud.com/80-series-tech/165504-possible-jdm-aux-c-fan-wiring-solution.html
https://forum.ih8mud.com/80-series-tech/315929-york-oba-install.html
Here are some pics in the order of appearance:
Finished install of Landtanks Charcoal Canister Bracket (pic borrowed from his thread)
the JDM bottle
US bottles (pic borrowed from Landtanks thread)
the JDM bottle
