After reading through the following writeup, my wheels started turning:
https://forum.ih8mud.com/80-series-tech/19299-transmission-fluid-exchange-writeup.html
What bothers me about exchanging the automatic transmission fluid via the method outlined in the quoted writeup is the potential to run the pump dry. In addition, I own (correction, used to own) one of the POS funnel/hose combos, and am very familiar with the potential for the flimsy tip of it to slip out of the tranny fill tube as I'm filling it. Unfortunately, I am also familiar with spilling the fluid all over the engine as I attempt to fill the funnel up and look at the fill markings on the side of the funnel.
My method is in the works. My goal here is to work out the kinks before I give it a shot. In other words, please do not be shy; criticize all you want.
Pre-exchange, I will do the following:
1) Drop the pan
2) Clean off the old gasket
3) Clean the metal filter & pan
4) Re-apply new liquid gasket
5) Re-assemble pan
6) Replenish the tranny with fresh ATF (fill to full line on dipstick)
By the way, Cruiserdan thought I was crazy when I attempted to order a new filter from him. I would have loved to see the look on his face.
Pictures of the exchange device (AKA The Homer):
The Homer (buckets purchased from The Home Depot)
Markings on new fluid bucket
Drain plug fitting (purchased from boating supply store)
Flow control valve - open (purchased from Lowes)
Flow control valve - closed
Flow control valve - partially opened
Coupler at end of 1/2" hose - to mate with return line (purcahsed from boat supply store)
Drain hose and Waste bucket with Quarts & Gallons marked on inside - water was used to mark measurements
Now for the exchange procedure:
I will intercept the fluid at the line attached to the top of the tranny cooler that runs back to the tranny inlet. To simplify things, I'll refer to this line as the "return line"; and the hose I will attach to the male end at the top of the tranny cooler to my bucket, the "drain line".
1) Remove the return line from the cooler
2) Attach the 1/2" hose to oil cooler, place other end in empty bucket
3) Attach the 1/2" hose (the one attached to "The Homer" supply bucket) to the return line. There is a 1/2" plastic coupler to join the two hoses
4) close the Homer valve
5) Place The Homer on a steady surface at a height above the engine level. I may use a 5' latter. That way you can put The Homer hose down through one of the holes on the top step of the latter. It would be a good idea to secure The Homer to the surface you set it on.
6) Fill The Homer with 5 Gallons of fresh ATF
7) Start the engine. Walk to front of rig (or have a helper sit in the drivers seat ready to shut her off should anything unexpected happen).
8) Observe the amount of old fluid flowing into waste bucket. Crack The Homer valve open to match the flow of old fluid exiting the system with the amount of new fluid being introduced via The Homer.
9) Shift through the gears slowly with foot on brake, obviously. Wouldn't want to run Homer over.
10) Shut off engine once 5 Gal (or whatever quantity it takes you to get clear fluid running from cooler to waste bucket) has passed through the system.
11) Re-attach return line to oil cooler.
12) Check fluid level.
13) Done, hopefully.
Well that's what I've got done so far. I'm open for discussion/comments. Refer to the quoted writeup for more information on this concept of exchanging your transmission fluid.
If this doesn't work, I'll have a fancy funnel to fill through the fill/dip stick tube.
1) Drop the pan
5) Re-assemble pan
epitaph known to
ers with opposable thumbs.
