The purpose of this Mod is similar to the Zero-Boost Turbo Mod described in a previous post, but this for the Supercharged Truck owner looking for the same goal of zero-boost driving. Several have indicated the desire to have no boost for wheeling and/or for lack of available high grade gasoline. This is a simple mod to do to a Supercharged truck - total install time was under 3minutes - and 10 seconds to remove. The Bypass valve for the SC is located to the Drivers Side of the throttle body, just forward of the T-body itself. The first shot shows the Valve in the Closed position, as you would see it with either the truck off, or the engine under full boost.
The second shot is with the valve zip tied open. I daisy-chained two 8in zip ties and reached under the SC near the Air Cleaner to feed up to the valve swing-arm plate. I road tested the mod, and got the results I predicted a year ago. The SC will generate some boost on the guage, but using a atmospheric-calibrated inHg aircraft guage I still have installed in the truck, the actual boost over atmosphere is less than 1psi under any load or rpm conditions. I would suggest the same test results would be found in the Sumo Zero-Boost Turbo Mod as well, since large enough bypass valves for 'true' zero-boost are tough to justify. Less than 1psi under any load should be a good enough target, given a blower fan is installed.
Just for S&G, I also tried removing the belt to compare results. The SC pulley does move under rpm load, and attains a true -0- boost, but this mod is a restriction to the intake as mentioned in other threads. I was seeing a rise in intake temps higher than the bypass valve mod which appears to confirm this is a restriction. I do not recommend removal of the belt, as the restriction dictates this appears to *not* be the same as running a truck without an SC. And is not equivalent to running an SC in Freewheel mode (belt on - bypass valve open). The intake manifold temp values without belt installed were less than a 6.5psi TRD, but I'd have concerns at high rpm under load with crappy gas.
HTH
Scott J
94 FZJ80 Supercharged
HTH
Scott J
