I have one that is seized and comming out soon, did not know if it was possible to make these little biatches run worth a krap?
robbie did his magic on a few...pricey, but awesome.
It is totally possible. Shave the head .030", port and polish the ports, bore it as big as it will go and start tweaking everything. Mine runs real strong but I am still chasing WOT detonation, although it is better with the colder air. I think a bump in fuel pressure may fix it. Search though. Many have been there before and documented it much better than I did.
overhanger, is your 3fe in the 250 to 260 hp range? how spendy was it?
250 to 260? HAHAHAHAHAHAHAAHA. Good one!
If this engine ever put out more than 200 hp after the rebuild, I'd be amazed. Pistons are 1.5mm (.060") overbore, largest OEM available, head was shaved the same 1.5mm, intake and exhaust ports were gasket matched, throttle body was overbored (can't remember that spec), crappy OEM exhaust system replaced by a larger single inlet cat/muffler arrangement and it all was tuned as well as Robbie could get it with a wideband O2 sensor in the exhaust to tune with. Figure that a 30% horsepower improvement over stock would net about 45 hp or so and 200hp is what you are looking at. Realistically, I'd say somewhere nearer to 180 is about what I got for my money and I'm happy with that. A 300,000 mile engine that doesn't necessarily have to travel in the slow lane on the hiway above 6000' when fully loaded with gear and has very good grunt on high altitude trails like Holy Cross and Red Cone in Colorado. It's a tractor motor and with the right gearing can get you were you want to go in fine fashion. That it could well last a half a million miles is a really big bonus.
There are some crate 3F engines available that are less expensive but still sweet and I don't mean MAF. OEM parts are expensive but worth it if you plan on keeping your truck for the duration - I do.
