Center Diff Lock
back to Chicago
Went wheelin' Sunday. Have a 97' LX450. When the truck's in 4-low, shouldn't the center locking diff engage and indicate on the dash? Mine wasn't doing so.
search id does not show up after a while. Either need to post links to actual threads or the parameters of your search
To answer your question the answer is YES
If you shift into 4-low (even if you have a CDL button IIRC) the center diff should lock and you get an idicator on the dash along with the ABS light coming on denoting ABS is shut off.
If your not getting any indication then you'll need to figure out why (guess that was pretty obvious huh :doh: :D)
I'd start by making sure the indicator lights work (during start up the ABS light should come on for a second or two but the CDL light/icon won't) and go from there.
Edit: corrected erroneous info :)
Romer, that is good to know! I never realized that :confused:
No one has the question...does it have a CDL lock button and has the 7 pin mod been done by the PO?
Doesn't have a cdl button or the 7-pin mod yet. ABS light comes on at startup, but not the center diff light. Also, I felt the ABS kick in a few times while decending in 4-low / 2nd.
I'd have to check to confirm the CDL icon lights up at startup :confused: - EDIT: Very TRUE. ABS icon lights up but CDL does not at startup check
One thing you could try is to shift in and out of low a LOT of times...I know I have read at least one post where an owner had issues getting the center diff to lock and after a LOT of shifts (50 or more IIRC) it finally started to work. One of those things that unless the PO went off road it probably rarely, if ever, got exercised.
I try to make a habit of hitting a dirt area at least once a month to exercise the center diff and front/rear lockers to keep them exercised. Pop in a CDL button and that makes exercising the center diff all that much easier :cool:
slinger5150,
I had the same problem. Turns out it was the indicator switch (84222-12010, cost around $45-$50)
Sounds like the switch to me. Sarah's truck had the same problem and the seller :D had to fix it.
Okay, got a CDL switch on dash, pin 7 mod done by PO. Same problem. No workie. What is the procedure for checking actuator switch? How much of a PITA is this going to be? Ran Holy Cross a few weeks back, worked fine, no hesitation on engaging or disengaging. Ran Spring Creek last Sat and not working.
Well, light in dash doesn't come on, neither the front nor rear diffs appear to lock. Or at least the lights for them just keep blinking. I can't hear anything that would indicate that they have engaged. Would checking the indicator switch be my first move, or find a dirt road and shift into low repeatedly? The CDL has worked before, and never gave me troubles at all, just sudden loss of operation.
Resurrected
O.k. went to put mine in low and the center diff lock does not seem to be engaging.
I checked it out when bought and even had the dealer run it through the paces and it worked. No CDL switch or 7-pin mod but I want to in the near future.
Tried today and I get no light on the dash, found this thread and determined it wasn't the problem. Tried leaving it in low and locking the front and rear and both just blink.
Question --- Could I have inadvertanly disconnected a connector while doing the 4x4 service or is this common to just go out? I also tried putting it into low (one thread, including this, said to keep trying to work the lever -- finally got tired of trying at around 35 pulls). I found George's write-up and will try this later tonight but any furthwer insight would be appreciated.
Any help would be appreciated.
Not to hijack the thread, but I have a similiar problem. Installed CDL, no 7 pin mod, put truck in Low and pushed the CDL switch and no CDL light - got the ABS light and it's been on ever since. Still no CDL light.
IDEAS???
Alright, here is the ultimate newbie question -- Where is the indicator located on the cluster to show the center diff is engaged. Picture would be cool.
Just played with it more during a break and I can hear what I beleive is the module in the kick panel switching but still nothing.
Glen
If you have the owners manual, it should show where it is.
