What is your intake manifold vacuum (inHg)?
How much do you get when properly tuned, idling?
Toyota specifies minimum 15 3/4 inHg
What do you get?
:hhmm:
21
:D
But the motor has less than 5K miles on it...
18
LOL !
That's cutting to the chase !
how about you just say what yours is, and we avoid beating around the bush.
Sorry dorcom, but I laughed at brian's comment. :lol:
I don't know mine. Never have hooked up a gauge to it. Hoping to change that soon. :)
I am at 16ish, should be higher. my BMW that I just rebuilt the engine 30k ago is at 21-22ish but I doubt the cruiser will ever be that good.
It depends...altitude, cam, timing, valve lash all affect vacuum.
19-21 at idle. 25-26 when off the gas coasting downhill. Less (much less) when standing on the skinny pedal.
Vacuum
Pretty much inline with Lugal on my gauge readings.
I have a vacuum gauge installed. I have 20- 21 at idle at sea level. Goes down at altitude. It's approx 18-19 at 4000 feet. At 60, at sea level, on flat ground no headwind it's between 12-14.
stop crying.:crybaby:
20
...not yet legal to consume alcohol...:cheers:
Thanks for the adult* answer!
You're like me! Vac gauge installed :cheers:
That is about what I get in the Bay Area (sea level) 20-21 @ idle.
Have yet to climb up a high mountain to see what's it up there.
Ranger, Can I drive up Mt. Shasta? I got 4 wheel drive!
Thanks again.
*PS Some seem to confuse vac (inHg) with phallus length. Oh well a male thing...
Ehm, my dick in inches/Mercury? Or my "bush" sucking power?
You confuse me, man! :doh:
Thanks for the "to the point" answer!
Me too! ROFL!
See my reply to him...
19-20 at idle at 800' elevation.
Vacuum SUCKS!
Dyno
So if I'm at 16 with timing set right on the BB then I need to be finding more leaks...better get back to the bat cave!!
