Does anyone know if the voltage is different between a 73-77 and the 79+ 22 gallon tank level sender.
I hooked the sender up for the first time last night and it shows 1/3 a tank when it is full. however, This is without a good ground connection. The ground seems to not make any difference at all in the reading.
Does anyone know if these years use different voltages? Since I have a 77 harness with a 79 tank, I may have to modify the sender and use the rod and float from the 79 and attach it to the 77 sender.
Or, these could both use the same resistance/ voltage and my sender is just bad, which is most likely the case.
